Post and beam Posted 1 hour ago Posted 1 hour ago (edited) 4th October marks the first full year of occupation of our new build. The heat pump has recorded 2650kWh for a cost of £703. This is taken straight from the Vaillant app and yes i know that some believe it to be potentially less than accurate. But ours is a very simple system so i am inclined to go with it unless i discover a reason not to. We have no gas supply so that is all of our heating and hot water. Happy with this. Now i need to try to get an accurate idea of what Octopus recorded for everything. Edited 1 hour ago by Post and beam Spelling 1
JohnMo Posted 1 hour ago Posted 1 hour ago Usage is pretty similar to ours when were doing DHW also. But not bad for heating and cooling. Now you have that information maybe worth comparing other tariffs and see how they work out as I assume the £703 is based on a standard tariff and has no solar (battery?) input.
SteamyTea Posted 1 hour ago Posted 1 hour ago 25 minutes ago, Post and beam said: The heat pump has recorded 2650kWh for a cost of £703 703[£] / 2650 [kWh] = 26.5p/kWh Something does not seem right there.
Post and beam Posted 2 minutes ago Author Posted 2 minutes ago 1 hour ago, SteamyTea said: Something does not seem right there. Why? 1 hour ago, JohnMo said: for heating and cooling Heating & hot water. I cut the cooling fraction out.
