MortarThePoint Posted September 29 Posted September 29 (edited) The pipework leading to a level ball valve, Caleffi 533201 PRV with integrated check valve and on to my unvented cylinder and rest of plumbing was installed ~3 years ago. It was filled with water and the first isolator closed. The pipe leading to that first isolator mostly drained though when the temporary feed was disconnected. The pipe was then capped and it has sat since with some water in. Below is a diagram of the pipework up to that closed level valve. The bottom most section of pipe (approx 3ft long) was probably half full of water. Below the diagram are some photos of the inside of the pipe. It looks like that fist horizontal section has some crystals on the top of the inside and black. I got the endoscope up to the first elbow and looking up the first vertical section it looks like is is probably just a bit of blackening. Questions: Is the pipe OK? That first horizontal section looks a little pitted, but is it nothing to worry about? Ideally I'd have a tee at the upper most 1ft horizontal to allow flushing the pipe back towards the brass inlet fitting. There's no movement in any of the pipework so cutting one in now would be tricky. A self cutting drain doesn't feel like a permanent fixture to me. Is there a cleaner I could use for 'static' flushing. I plan to pressure test the pipe with water at 10bar. That will force water 90% of the way up towards the Closed Valve. That would allow a near zero flow rate flush which is what I mean by a 'static' flush. Note: No drinking water will be consumed through any of this pipe. Note2: I couldn't be bothered to set the date on the endoscope but the images were today. Note3: it's all 22mm pipe Edited September 29 by MortarThePoint
Nickfromwales Posted September 29 Posted September 29 Metals fair better when fully immersed. Standing water left behind that cannot vent off often promotes corrosion or oxidisation forming, so always best to fill the whole pipe run, purge it clear, and cap it off and leave it under pressure (eg fit the cap, and then open the valve and close it again to keep it full and under pressure).
MortarThePoint Posted September 29 Author Posted September 29 14 minutes ago, Nickfromwales said: Metals fair better when fully immersed. Standing water left behind that cannot vent off often promotes corrosion or oxidisation forming, so always best to fill the whole pipe run, purge it clear, and cap it off and leave it under pressure (eg fit the cap, and then open the valve and close it again to keep it full and under pressure). Makes sense. What would you do at this point though?
Nickfromwales Posted September 29 Posted September 29 5 hours ago, MortarThePoint said: Makes sense. What would you do at this point though? Nothing really. 6 hours ago, MortarThePoint said: No drinking water will be consumed through any of this pipe. So zero impact. Will likely wash out, after x number of litres has flowed through it / over time. People are bathing in dead pigeon / marinated mouse water every day, if they have cold water storage tanks in their attics, and to the best of my knowledge these folk simply enjoy ignorant bliss; none have sprouted feathers or grown tails, I am reliably informed…. 2
MortarThePoint Posted September 29 Author Posted September 29 My plan is to do a 10bar pressure test with deionised water for 1 hour and then violently vent it so that there is a good flow rate through that lower section. If it passes that, then all good in my eyes. Deionised water may help to dissolve some of the crud, if not no worries. 1
marshian Posted September 29 Posted September 29 2 hours ago, Nickfromwales said: People are bathing in dead pigeon / marinated mouse water every day, if they have cold water storage tanks in their attics, and to the best of my knowledge these folk simply enjoy ignorant bliss; none have sprouted feathers or grown tails, I am reliably informed…. I've had a cold water store in the loft for the 35 years we have been in this house - I've never found anything in it except for a little bit of sand and limescale - am I alone in feeling left out of this joyous discovery?
Nickfromwales Posted September 29 Posted September 29 38 minutes ago, marshian said: I've had a cold water store in the loft for the 35 years we have been in this house - I've never found anything in it except for a little bit of sand and limescale - am I alone in feeling left out of this joyous discovery? Yes. Stop stealing my over-dramatic thunder please. 🙏🤫🤐 2
Nickfromwales Posted September 29 Posted September 29 23 minutes ago, Onoff said: Call that crud? I bet that finger could tell some stories…… 🤔 2
marshian Posted September 30 Posted September 30 12 hours ago, Nickfromwales said: Yes. Stop stealing my over-dramatic thunder please. 🙏🤫🤐 Apologies.............
Nickfromwales Posted September 30 Posted September 30 11 hours ago, marshian said: Apologies............. I will forgive you, may just take some time.
