September 24Sep 24 I am a bit confused by the instructions on the resin stone shower tray we have bought. It says to lay a bed of mortar 15mm thick over the entire base, lay the shower tray on top and "manipulate tray a minimum of 5mm into the bed to ensure the underside of the tray is FULLY supported". Emphasis on fully. The tray is a non-slip one, long and has quite a steep angle, with ribs underneath. The ribs are 20mm thick at the "shallow end". If I only manipulate the tray 5mm into the bed, only the ribs are going to be supported, not the entire underside of the tray. Am I overthinking this? Do they just mean that all the ribbed bits need to be bedded in 5mm into the mortar? 75% of the mortar is going to be doing sod all on that basis 😅
September 24Sep 24 Yes, you're overthinking it. As long as the ribs are supported, the bit you will be standing on will be plenty strong enough. FYI - one of ours sits on a wooden frame suitably waterproofed
September 24Sep 24 Author 7 minutes ago, BotusBuild said: Yes, you're overthinking it. As long as the ribs are supported, the bit you will be standing on will be plenty strong enough. FYI - one of ours sits on a wooden frame suitably waterproofed Thank you. I thought I probably was but have never fitted a modern stone shower tray before. I have done plenty of old fibreglass ones in the past but they were so cheap I didn't care if I got it wrong. This one, was not.
September 24Sep 24 1 hour ago, andreas said: I am a bit confused by the instructions on the resin stone shower tray we have bought. It says to lay a bed of mortar 15mm thick over the entire base, lay the shower tray on top and "manipulate tray a minimum of 5mm into the bed to ensure the underside of the tray is FULLY supported". Emphasis on fully. The tray is a non-slip one, long and has quite a steep angle, with ribs underneath. The ribs are 20mm thick at the "shallow end". If I only manipulate the tray 5mm into the bed, only the ribs are going to be supported, not the entire underside of the tray. Am I overthinking this? Do they just mean that all the ribbed bits need to be bedded in 5mm into the mortar? 75% of the mortar is going to be doing sod all on that basis 😅 I would never use mortar, and have only ever used flexible tile adhesive. FYI I have been 'at this' for over 30 years, and have done more wet-rooms than I can remember. Not ONCE have I used mortar for this and I cannot fathom why they are still suggesting you do so in 2026! Mortar was used "during the war".
September 24Sep 24 Author 3 minutes ago, Nickfromwales said: I would never use mortar, and have only ever used flexible tile adhesive. FYI I have been 'at this' for over 30 years, and have done more wet-rooms than I can remember. Not ONCE have I used mortar for this and I cannot fathom why they are still suggesting you do so in 2026! Mortar was used "during the war". Thank you - that interests me. How thick a bed would you use if you are using flexible tile adhesive? Any recommendations for which one? Do you use quick setting or normal, and how wet do you mix? The base is 18mm ply on raised joists. LOL sorry that is a lot of questions but I've not heard of that before.
September 24Sep 24 5 minutes ago, andreas said: Thank you - that interests me. How thick a bed would you use if you are using flexible tile adhesive? Any recommendations for which one? Do you use quick setting or normal, and how wet do you mix? The base is 18mm ply on raised joists. LOL sorry that is a lot of questions but I've not heard of that before. The thickness of the bed is based on how well you laid the ply, in a nutshell. The stone you refer to, is probably 'stone-resin', is that correct? Either way, the biggest issues with this type of install is failing to clean (decontaminate) the underside of the tray; most of these are either covered in mould release agents (or remnants of), or are dust-covered from the underside being ground flat prior to dispatch. Both of those will stop anything sticking well to the underside, so needs addressing. I recommend using some tile adhesive on a cotton cloth and using it like Ajax to 'scour' the underside. This will clean the tray and leave it ready to stick the adhesive to excellently. I would mix this to a consistency similar to clotted cream, and if you're a novice then I would use a "standard" or "extended" set adhesive vs rapid, as this will give you an additional hour or more to feck about with it. Rapid will start to cure more or less as it hits the ply. I use Ultra tile adhesive, but Bal or Mapei are all very good gear; much of a muchness I am sure. You need to SBR (PVA on steroids) the plywood before installing the tray btw, so the tile adhesive sticks to that like shit to a blanket. You should do this around an hour before fitting the tray. The 2 or 3 sides of the tray that are abutting the walls should be filled up with clear CT1, NOT SILICONE, and that will complete the install for a trouble-free life.
September 24Sep 24 Author 14 minutes ago, Nickfromwales said: The thickness of the bed is based on how well you laid the ply, in a nutshell. The stone you refer to, is probably 'stone-resin', is that correct? Either way, the biggest issues with this type of install is failing to clean (decontaminate) the underside of the tray; most of these are either covered in mould release agents (or remnants of), or are dust-covered from the underside being ground flat prior to dispatch. Both of those will stop anything sticking well to the underside, so needs addressing. I recommend using some tile adhesive on a cotton cloth and using it like Ajax to 'scour' the underside. This will clean the tray and leave it ready to stick the adhesive to excellently. I would mix this to a consistency similar to clotted cream, and if you're a novice then I would use a "standard" or "extended" set adhesive vs rapid, as this will give you an additional hour or more to feck about with it. Rapid will start to cure more or less as it hits the ply. I use Ultra tile adhesive, but Bal or Mapei are all very good gear; much of a muchness I am sure. You need to SBR (PVA on steroids) the plywood before installing the tray btw, so the tile adhesive sticks to that like shit to a blanket. You should do this around an hour before fitting the tray. The 2 or 3 sides of the tray that are abutting the walls should be filled up with clear CT1, NOT SILICONE, and that will complete the install for a trouble-free life. Really appreciate the additional info. The ply has been laid pretty well, it's about 3mm adrift of perfectly level over a span of 1500mm with no humps or voids, just slightly on the piss (I only discovered after laying it that my spirit level had been knocked out of adjustment) What thickness would you recommend on that basis? I worked out 35kg mortar to get to 15mm thickness over the area so if it can go thinner that would be great. Yes you are correct, stone resin. You're dead right about the contamination too, it looks like the aftermath of a Hollywood coke party underneath, I'll get scouring. It all had a couple of coats of SBR already as I was not very happy with the quality of the ply. It's supposedly marine but I am doubtful, I did stick an offcut in water for a week and it didn't delaminate so it is at least WBP. I was going to stick another coat on before mortar just as it's got a bit dusty and dirty I'll get to the shops in the morning, have CT1 handy already from installing the jackoboard but will pick up some adhesive. Thanks again
September 24Sep 24 44 minutes ago, andreas said: Really appreciate the additional info. The ply has been laid pretty well, it's about 3mm adrift of perfectly level over a span of 1500mm with no humps or voids, just slightly on the piss (I only discovered after laying it that my spirit level had been knocked out of adjustment) What thickness would you recommend on that basis? I worked out 35kg mortar to get to 15mm thickness over the area so if it can go thinner that would be great. Yes you are correct, stone resin. You're dead right about the contamination too, it looks like the aftermath of a Hollywood coke party underneath, I'll get scouring. It all had a couple of coats of SBR already as I was not very happy with the quality of the ply. It's supposedly marine but I am doubtful, I did stick an offcut in water for a week and it didn't delaminate so it is at least WBP. I was going to stick another coat on before mortar just as it's got a bit dusty and dirty I'll get to the shops in the morning, have CT1 handy already from installing the jackoboard but will pick up some adhesive. Thanks again Thickness is just anything more than 5-10mm, and if you want to go nuts just pack out all the voids with tile adhesive and lay that into the bed of adhesive for ‘concrete solid’. I am OCD and go belt and braces, but I’ve never had a single callback EVER and sleep very well at night.
September 24Sep 24 Would you go SBR over say Ultra Pro Primer Nick? I'll be doing my floor tiling job in the near future so I'm interested as I'm about to order my supplies.
September 24Sep 24 47 minutes ago, Super_Paulie said: Would you go SBR over say Ultra Pro Primer Nick? I'll be doing my floor tiling job in the near future so I'm interested as I'm about to order my supplies. One or the other. Basically, if water’s getting to it you’re Donald Ducked anyways. Bump a thread when the time comes and we’ll ‘learn you good’
