Foam for Sealing Compressor Air Line
Hi folks, my sewage treatment plant manufacturer says to use a foam to seal the air lines at either end of the air hose going from my air compressor to the plant. Cann anyone please tell me what type of foam to use. Cheers !
Arenite
Difficult one.
Can you post a picture up?
You may find that a non foaming  flexible PU adhesive is better than expanding foam.
Mine came with a bit heavy duty black neoprene type bung that had a hole pre cut in the centre
a bit of a tight fit that I rammed inside the duct.
  • 1 month later...
I would go with Russell on this one. A tight neoprene bung is the safer bet, as expanding foam can push into the hose and choke the air supply without you noticing at first. If you do use a sealant, keep it to a flexible, non expanding type around the outside only, and check the plant is still getting a good airflow after you seal it.
