Super_Paulie Posted August 29 Posted August 29 Just about to rough fit my iBox2. The manual states the connection is RP 1/2, is that just a normal half inch fitting? Never heard of anything labelled RP before so just thought I'd check what you guys with experience think.
Nickfromwales Posted August 29 Posted August 29 10 minutes ago, Onoff said: Standard 1/2" BSP, parallel threads. Yup. Hep2o do a pushfit 15mm x 1/2” male BSP, or you can get the same in compression.
garrymartin Posted August 30 Posted August 30 (edited) 17 hours ago, Nickfromwales said: Hep2o do a pushfit 15mm x 1/2” male BSP, or you can get the same in compression. Not the best photo, but I can't find anything better - this is push-fit (Flomasta I think) 22mm x 3/4" BSP male in the iBox. Worked really well. Edited August 30 by garrymartin
Nickfromwales Posted August 30 Posted August 30 1 hour ago, garrymartin said: Not the best photo, but I can't find anything better - this is push-fit (Flomasta I think) 22mm x 3/4" BSP male in the iBox. Worked really well. Yup. iBox’s to date have mostly been 3/4”, which I fit a 3/4 x 1/2” bush into, then a 15mm x 1/2” male adaptor. Not used 22mm on a shower for a long time, and that was a Chinese monster shower / steam cubicle thing with 30 odd jets and a 16” rainfall head; fed from gravity and a 3bar 22mm Stuart Turner twin impeller pump. Shower internals and shower heads etc can only cope with so much lpm flow rate & pressure, done some where the rubber nozzles start popping out
garrymartin Posted August 30 Posted August 30 3 hours ago, Nickfromwales said: Not used 22mm on a shower for a long time It's a bath filler.
Nickfromwales Posted Monday at 07:00 Posted Monday at 07:00 14 hours ago, garrymartin said: It's a bath filler. I may need to look for a new job 🤣 1
