August 24Aug 24 all house is UFH but the upstairs was done with cut out polystyrene panels that they pushed the pipes into in the room with ghosts the supply to an ajoining bathroom and dressing room pipes also run around the perimeter sometimes when things go on I get noises downstairs like someone is walking about on a creaky floor I am guessing it is the panels moving when I told the builder and suggested that maybe the panels should have been stuck down -- he assure me -- as you would expect that they are not supposed to be stuck down --according to maker another lie i presume? impossible to fix now as there is self levleling layer and stuck down lvt on top
August 24Aug 24 Ours needed to be stuck down with Rapid Bond, a polystyrene safe spray. I'd be very surprised if any polystyrene boards could be dry laid, they're really weak, just a few mm, where they're routed out. Can you ask the board manufacturer? I'm guessing you only have a few mm of leveling compound over?
August 24Aug 24 Author 1 hour ago, torre said: Ours needed to be stuck down with Rapid Bond, a polystyrene safe spray. I'd be very surprised if any polystyrene boards could be dry laid, they're really weak, just a few mm, where they're routed out. Can you ask the board manufacturer? I'm guessing you only have a few mm of leveling compound over? what ever the casue and some more investigation since i posted tells me the cement board that are laid over the piping sheets --to act as heat sink should also be glued together with a special foaming type adhesive which allows for movement so the solution is not one i want to contemplate --ripping it all up and doing it the right way--i cannot see the builder doing it and cost to do would be very high new lvt -- new self levelling and cement boards etc - i think i will have to live with my ghosts
August 24Aug 24 I'd also be reluctant to do anything drastic and expensive, hopefully the whole floor will float but stay flat and you'll get used to the creaks. One possible explanation might be a lack of expansion gaps around the edges of the room, so if you do ever need to investigate further I'd start by taking all the skirting off before doing anything to the floor itself Edited August 24Aug 24 by torre typo
August 24Aug 24 Author 4 minutes ago, torre said: I'd also be reluctant to do anything drastic and expensive, hopefully the whole floor will float but stay flat and you'll get used to the creaks. One possible explanation might be a lack of expansion gaps around the edges of the room, so if you do ever need to investigate further I'd start by taking all the skirting off before skiing anything to the floor itself all skirtings were fitted after cement board and self leveling -but before LVT-- so the grinder did not damage the skirtings i ma guessing there is too much of a gap inthe poly/pipe boards and that why they are moving -- all guess work Edited August 24Aug 24 by scottishjohn
August 25Aug 25 12 hours ago, scottishjohn said: all skirtings were fitted after cement board and self leveling -but before LVT-- so the grinder did not damage the skirtings i ma guessing there is too much of a gap inthe poly/pipe boards and that why they are moving -- Might still be worth removing the skirting board. If there is not enough gap it can be made bigger and if too much can be filled with something compliant to reduce movement. It's possible there is a gap at higher layers and not at lower layers or vice versa.
