saveasteading Posted 2 hours ago Posted 2 hours ago I'm getting conflicting info re preparing the screed for timber flooring. In other words, people like spending my money. Where there is tiling, we have no issues. The screed has not been ground back to remove ripples or laitence. Dips and ridges disappear using the tiler's skill and some double buttering. In the other rooms we will have oak faced multi ply planks, t and g, 12mm thick. I can't see what is different in laying this instead of tiles. But someone says the screed needs to be ground to remove ripples and laitance. Someone else says it needs latex at any dips. The floor planks are very high quality and won't be bending or slapping in use unless the gap is significant. I'm about to survey all the floors using a 3m straightedge, and will consider the 3mm rule as a pass. Any thoughts on that? Does anyone know how thick the adhesive is as standard, or what might be considered acceptable at any dips? Then the laitance thing. These floors only receive downwards loading and won't be flying up in a draught. But is the screed surface so soft that it comes off if the floor moves? I was thinking that a coat of primer would suffice. And if it's a blue colour then everyone will be happy to see it. Any very big dips or ridges will be dealt with on their demerits... I will soon know the significance.
-rick- Posted 1 hour ago Posted 1 hour ago (edited) Double post? Other one here: Edited 1 hour ago by -rick-
