stephanh Posted Friday at 09:07 Posted Friday at 09:07 I have installed a Matrix STP. With current enviroment conditions I wonder whether the out flow from the STP could be reused for irrigation purposes. I have been advised that the answer to that is NO. Has anyone gone down this route successfully?
Nickfromwales Posted 6 hours ago Posted 6 hours ago On 14/08/2026 at 10:07, stephanh said: I have installed a Matrix STP. With current enviroment conditions I wonder whether the out flow from the STP could be reused for irrigation purposes. I have been advised that the answer to that is NO. Has anyone gone down this route successfully? Irrigation requires a LOT of volume of water, nowhere near enough would come from this type of plant. The person advising you is kosher, it's a "no". . Irrigation from dedicated RWH systems for these types of current circumstances would, for context, need to be 15,000-20,000L capacity to be anywhere close to being considered 'effective', as the amount of stored water needed to get from 'drought to drought' is huge.
saveasteading Posted 5 hours ago Posted 5 hours ago On 14/08/2026 at 10:07, stephanh said: wonder whether the out flow from the STP could be reused for irrigation purposes. I have been advised that the answer to that is NO. Volume? Of course it depends on the garden needs, but it's a decent amount of water. But it would be quite low in the ground and might need pumping. Health and safety wise? Everyone will say no, and probably rightly so. But what comes out generally looks clear and I know it hasn't killed trees I've had drains near to. My hunch is probably no harm with decorative plants or trees but should not be used for vegetables.
