Del-inquent Posted 14 hours ago Posted 14 hours ago Yes this is probably a stupid question but I’m second guessing myself here… old shower mixer (very, very old) has hot on right, cold on left. new mixer has hot on left, cold on right. Plumbing access is minimal and would mean a lot of work. New mixer is fully symmetrical and has a cover plate that means in theory I can just stick in straight in, as long as it is mounted upside down. Am I missing any obvious issues with doing that?!
Nickfromwales Posted 14 hours ago Posted 14 hours ago 3 minutes ago, Del-inquent said: Yes this is probably a stupid question but I’m second guessing myself here… old shower mixer (very, very old) has hot on right, cold on left. new mixer has hot on left, cold on right. Plumbing access is minimal and would mean a lot of work. New mixer is fully symmetrical and has a cover plate that means in theory I can just stick in straight in, as long as it is mounted upside down. Am I missing any obvious issues with doing that?! The control handles are sometimes restrictive of doing so. Are these rotary dials, or levers? Also, you’ll either mount the cover plate the ‘right’ way, or have the text inverted. 1
Del-inquent Posted 6 hours ago Author Posted 6 hours ago 7 hours ago, Nickfromwales said: The control handles are sometimes restrictive of doing so. Are these rotary dials, or levers? Also, you’ll either mount the cover plate the ‘right’ way, or have the text inverted. Centre is rotary, above and below are levers but all clear of any obstructions. The plate can be rotated back the correct way judging by the technical drawings so that at least isn't an issue. As long as there isn't anything else I'm overlooking think I'll just go for it and see what happens! It'll save a load of demolition and upheaval.
gaz_moose Posted 5 hours ago Posted 5 hours ago I think it would give weird results and be hard to get a temperature from. on a different house i had a mixer cartridge that was dying and when you flushed a toilet it would cause the shower head to drip a decent amount of water ( about a mug) as the cold was sucking from the hot side. So i wonder if it would cause some kind of issue that way. I have heard of bathroom fitters getting the supplies mixed up and having issues but cant remember the issues.
