Ferdinand Posted 18 hours ago Posted 18 hours ago Nothing for weeks, then two questions come along together. Spotted today about 100m short of our local marketplace. This was a former barbers modified to be a small bungalow within the last 2 years. Is that outward swing allowed? It used to be a plate glass shop front. The pavement is about 2.2m wide. AIUI they can only swing out over 2.4m in height. I'm not happy about that as it is a busy route into town, I think it is unacceptable under both Obstruction of a Public Highway, and Building Regs "Safety from Collision". I'm thinking eg of Vision Impaired Long Cane or Guidedog Users, who in our town may be at the wall not the kerb because pavement parking is endemic - they put their vehicles halfway over the pavement so they can get out inside the marked parking bay, everywhere. (My thought: I think not and this is down to both designer and District Council uselessness and / or laziness - continental style inward-going tilt and turn windows are available everywhere, and would be more secure anyway.) I think the fix is to replace the lower pane with a fixed light. I would welcome any comments. Cheers Ferdinand
kandgmitchell Posted 18 hours ago Posted 18 hours ago The Building Regulation requirement K5 Protection from collision with windows does not apply to dwellings so that's a non-starter for a bungalow. I'm surprised Highways have missed this at the planning stage, they are usually keen to avoid obstructions (of course it may have been a planning requirement that's been ignored). It's an obvious risk to people with a visual impairment. Assuming a 600mm wide casement this could reduce the pavement to 1.6m wide. Contact highways via their online reporting system and get them to require the change to inward/tilt opening windows as it should have been from day one.
Ferdinand Posted 11 hours ago Author Posted 11 hours ago 14 minutes ago, kandgmitchell said: The Building Regulation requirement K5 Protection from collision with windows does not apply to dwellings so that's a non-starter for a bungalow. I'm surprised Highways have missed this at the planning stage, they are usually keen to avoid obstructions (of course it may have been a planning requirement that's been ignored). It's an obvious risk to people with a visual impairment. Assuming a 600mm wide casement this could reduce the pavement to 1.6m wide. Contact highways via their online reporting system and get them to require the change to inward/tilt opening windows as it should have been from day one. I'll try it. I rather expect them to "No Further Action" it, as they did last week with a wheelchair blocking barrier ("does not meet our criteria for intervention") which requires a mobility aid user, or some pram-pushers, to go an extra half mile to get into teh local churchyeward from their estate.
torre Posted 10 hours ago Posted 10 hours ago I agree that's a danger. Looks like section 153 of the highways act 1980 is what you should quote when contacting the highways department.
FarmerN Posted 1 hour ago Posted 1 hour ago It appears to be within the roof overhang, Who owns the land it’s opening into? Is it the window that’s wrong or the pavement? Agree it does no appear safe.
