Would anyone happen to have any details or technical drawings relating to a portal frame construction to make a gable window? Our structural engineer is designing the steel structure but it would be useful to see any past projects/hear your experiences.
We constructed our frame in 90mm square hollow tube, it is around 3 to 4mm wall thickness.  Then we attached timber to the outside face and the windows sit in the wooden frame and in front of it.  As the frame attached below insulation level its a thermal bridge so needs to be insulated internally
