June 5Jun 5 It looks like i will need to provide a ramp/slope from the driveway to the path in front of the house. This will also need to be SUDs compliant i guess. So what is the recognised and preferred method to do so? All of the articles i can find so far describe the build up of a flat and level surface.
June 5Jun 5 There is a roads document that details the slopes required and where the acro drain is located so you don't get slippage on to the road. It basically has to comply with highways regs. Your slope itself is likely to have to SUDs compliant also
June 5Jun 5 Author I may not have explained myself very well. The slope is only for wheelchair access because my driveway will likely be about 300-400mm higher than the level path to the front door.
June 5Jun 5 1 hour ago, Post and beam said: The slope is only for wheelchair access If you build it with a very slight slope to one side then most water won't reach the bottom. A gravel trench of about 100 x 100 might suffice along the edge. At the bottom you can continue whatever your drainage is for the drive.
June 5Jun 5 We did our drive way with permeable Marshals paving, but it slopes away from to house , it sounds like your slopes towards house, so will require a very good drain channel. Ours does work well in light rain but we get run off in very heavy rain and in the gateway that gets most traffic/mud it is starting to seal after two years. Marshals say it does not clog. https://www.marshalls.co.uk/landscaping/tools-and-support/permeable-paving-suds Paving we used- https://www.marshalls.co.uk/landscaping/commercial-paving/products/tegula-permeable-paving
June 5Jun 5 I too want to know the answer to this and haven't been able to find it. The principle of SUDS is that the sub base acts like a water tank, storing the water until it can drain away into the underlying ground. As soon as you put that on a slope, you are tilting the tank and reducing the amount of water it can store - like tipping a tray of water. Logically there is no solution to this other than make the bottom of the "tank" level, which hugely increases the volume and cost, or an ACO drain at the bottom to a soak away.
June 6Jun 6 8 hours ago, Ed_ said: reducing the amount of water it can store Or you can take a drain/ trench of gravel off at right angles to take water away, as a soakaway, or have a small sump type of soakaway, as the quantity will be small. @Post and beam how long will this path be? Does it need a resting platform half way? What paving material, thinking ahead to frost.
June 8Jun 8 Author On 06/06/2026 at 08:23, saveasteading said: how long will this path be? My slope path probably only about 5 to 7 metres. So it needs to be no more than 4.8 degrees for 5 metres down to 3.8 degrees if its any more. I could lower the whole of the driveway area to remove this wheelchair friendly path but then i have a steeper exit onto the road.
