B&Q Spacepro brand. MIs say 2260 is the frame height, width 3m.
So my opening is 2270 at one side 2280 at the other.
How do I do this?
Was thinking a bit of 19mm planed timber attached to ceiling and plane it to remove the extra 10mm? Will it bend enough?
Thoughts welcome...
Floor is square, ceiling has been plastered after a leak and I reckon its the ceiling that's off-sloped.
Plan A is to cut a timber to 2260 then mark out the gap every 150mm or so across the 3m opening
Hold the chunk of timber up to the ceiling on a couple of props
measure up from floor both ends and mark the timber
use a block of timber to scribe the ceiling contour on to your length of timber
plane it to fit.
  • 2 weeks later...
Just to finish this off. The Spacepro fittings have around 25mm of travel in the brackets, so they can slide up and down.
My 10mm slope was no issue at all they slide like a half cut, suncream soaked Scotsman on Spanish flume.
Job done, daughter happy
