carlos21 Posted 6 hours ago Posted 6 hours ago Hi iam hoping to fit french doors into a new build extension, the wall is concrete block with cavity and pir insulstion. Is the positioning of the door within the wall the same as with windows? Ie mostly inline with the insulation. Are the doors then fixed in place with tie straps? I have found a second hand door which is the right colour etc but is about 200mm narrower in width, and iam wondering the best way to make good on the exterior. If the door is positioned inline with the insulation should i place compqfoam in the cavity for a base. Hope this makes sense, a few photos of the doorway at present. Thanks carl
