G and J Posted March 1 Posted March 1 I have a cunning plan my lord.  Above my UVC I’m going to use a HEP2O 22mm x 10mm manifold daisy chained with a HEP2O 22mm x 15mm manifold, both closed spigot versions.  I won’t need to open the closed spigot on the second manifold, but I will the first one.  Can I find instructions as to how exactly to do it?  Not even slightly.  AI tells me to use a HEP2O key (duh!), bless it.     But do I just cut it off?  If so, where exactly?  Where it narrows as indicated my my red arrow? And do I use an insert?  Oh the stress!   If a passing grown up knows the answers I’d be ever so grateful….
Nickfromwales Posted March 1 Posted March 1 7 minutes ago, G and J said: I have a cunning plan my lord.  Above my UVC I’m going to use a HEP2O 22mm x 10mm manifold daisy chained with a HEP2O 22mm x 15mm manifold, both closed spigot versions.  I won’t need to open the closed spigot on the second manifold, but I will the first one.  Can I find instructions as to how exactly to do it?  Not even slightly.  AI tells me to use a HEP2O key (duh!), bless it.     But do I just cut it off?  If so, where exactly?  Where it narrows as indicated my my red arrow? And do I use an insert?  Oh the stress!   If a passing grown up knows the answers I’d be ever so grateful…. Yes, where the red arrow is.   Use the pushfit pipe cutter, slight rotation as you cut.
G and J Posted March 1 Author Posted March 1 1 hour ago, Nickfromwales said: slight rotation as you cut. OK thank you.   Do I turn to my left or my right?  😉Â
Nickfromwales Posted March 1 Posted March 1 7 minutes ago, G and J said: OK thank you.   Do I turn to my left or my right?  😉 One way the cutter tries to open, the other it wants to bite down. You need the latter. Practice on a piece of 22mm pipe then cut the fitting.
G and J Posted March 1 Author Posted March 1 3 minutes ago, Nickfromwales said: One way the cutter tries to open, the other it wants to bite down. You need the latter. Practice on a piece of 22mm pipe then cut the fitting. So is it just a slight turn to my right then, not like a full pirouette or anything.  I’d better make sure I’m not standing next to a wall or I’ll bang my nose as I spin round lol
Nickfromwales Posted March 1 Posted March 1 1 minute ago, G and J said: So is it just a slight turn to my right then, not like a full pirouette or anything.  I’d better make sure I’m not standing next to a wall or I’ll bang my nose as I spin round lol Don't forget to have 5 pints of Stella first.
JohnMo Posted March 1 Posted March 1 48 minutes ago, Nickfromwales said: Don't forget to have 5 pints of Stella first. But won't cut it, on pissed angle then
Nickfromwales Posted March 1 Posted March 1 17 minutes ago, JohnMo said: But won't cut it, on pissed angle then Shhhhhh. You'll spoil the surprise.
