hauntedicecreamvan Posted January 27 Posted January 27 (edited) I'm looking to replace all my windows. Most windows are a mix of either 2400x1200 or 1200x1200 squares. Currently they are mostly split with a vertical mullion into 2x 600x1200 or side casements with a large fixed central pane, but the design of the property looks so much better with the original simple square windows. I understand that 1200x1200 is right on the limit of a standard uPVC awning window when using 4-20-4 glazing, and exceeds it for 6-18-4. Anecdotally I've seen large uPVC awning windows fitted to properties and they felt so flimsy and were barely usable after a few years, whereas my smaller 600x1200 openers are fine after 30-odd years. I can't fit tilt and turn due to obstructions in the window reveals internally. I see that fully reversible systems like Rehau Total70R allow up to 1400x1400 sashes. They have a "flush casement" appearance when closed, and some systems have a brush pile to cover the hinge slot. I don't need any of the reversible features, although even on ground floor I suppose it could make cleaning easier since you're standing higher inside. Does anyone here have these windows? Any disadvantages to be aware of? I guess they require more care with squaring the frame and toe-and-heeling glass during installation. Edited January 27 by hauntedicecreamvan
Russell griffiths Posted January 27 Posted January 27 My windows by norrsken spin right around I’m not sure if that’s exactly what you want, but I’ve been nothing but impressed with them since fitting 4 years ago. 1
