kentar Posted Tuesday at 17:16 Posted Tuesday at 17:16 (edited) I need something that can go outside next to the house. I'm not bothered if it's ground mount or wall mount. Height and width don't matter. The only restriction I have is that i'm limited on depth to 250mm. I've found Fogstar have just come out with a battery that fits the bill but it's on preorder. I'll need 2 of them. https://www.fogstar.co.uk/collections/server-rack-batteries/products/fogstar-energy-ip-rated-16-1kwh-48v-solar-battery Are there any other options that are immediately available and don't break the bank? Edited Tuesday at 17:17 by kentar
Nickfromwales Posted Tuesday at 21:04 Posted Tuesday at 21:04 Seen some wall mounted external Givenergy units recently, seemed to not project too far from the wall, but Tesla prob worth a look too. I guess just googling the dims of various units is your best bet.
Nickfromwales Posted Tuesday at 21:05 Posted Tuesday at 21:05 How long is the wait for Fogstar? You can’t become huge rush, and @jack has one of their units iirc.
Andehh Posted Tuesday at 21:26 Posted Tuesday at 21:26 (edited) Also interested to know! I want the battery in the external garage, but the fuse box and solar inverter is in the utility room. I have 2 x armoured cables, and 2 x Cat6a, running between the two, originally for car chargers, can these be used to connect the battery to the house? I have no comms cables installed, is this an issue? Thanks Edited Tuesday at 21:28 by Andehh
-rick- Posted Tuesday at 21:52 Posted Tuesday at 21:52 22 minutes ago, Andehh said: I want the battery in the external garage, but the fuse box and solar inverter is in the utility room. I have 2 x armoured cables, and 2 x Cat6a, running between the two, originally for car chargers, can these be used to connect the battery to the house? I have no comms cables installed, is this an issue? No. With a 48V battery you need really thick cables for even a short run as you are looking at ~100A current, it'll get very expensive and inefficient to run long lengths of cable. The batteries should be within a metre or two of the inverter. If you want a long run between the solar inverter and battery, maybe best to look at AC coupled batteries (either that come with their own inverter or install a seperate one for them) or look at the high voltage battery options (though even then I'm not sure how keen you'd find installers to go down that route as it won't be a standard option).
kentar Posted Tuesday at 22:01 Author Posted Tuesday at 22:01 It seems Fogstar offer the best bang for buck. 2x 16kwh batteries comes out to £4k. Thats £125/kwh. I don't think there's anyone else who comes close. I'm trying to get to a point of being cost negative. How much money can I generate from this? I don't know what my energy usage will be. I'm currently in the process of speccing a ASHP install. I've been told my heat loss is above 10kw, so i'll likely be fitting a 12kw heat pump.
JohnMo Posted Tuesday at 22:06 Posted Tuesday at 22:06 1 minute ago, kentar said: I've been told my heat loss is above 10kw, so i'll likely be fitting a 12kw heat pump. Don't assume the heat loss is correct check for yourself. I have been told by two companies I needed a 10kW ASHP, will be installing a 4kW on Saturday. Certainly don't install anything bigger than you need as part load performance (average winter day) will suffer. 4 minutes ago, kentar said: How much money can I generate from this? Do you have PV?
-rick- Posted Tuesday at 22:06 Posted Tuesday at 22:06 2 minutes ago, kentar said: It seems Fogstar offer the best bang for buck. 2x 16kwh batteries comes out to £4k. Thats £125/kwh. I don't think there's anyone else who comes close. They are very competitive. Not sure how many installers use them though so you might have to hunt a bit if relying on someone else to install. 2 minutes ago, kentar said: I'm trying to get to a point of being cost negative. How much money can I generate from this? I don't know what my energy usage will be. I'm currently in the process of speccing a ASHP install. I've been told my heat loss is above 10kw, so i'll likely be fitting a 12kw heat pump. First step, is look again at the heat loss. Is this building either very big or almost uninsulated? 10kw is very high, but equally this forum is littered with threads from people coming here with specs from an installer of similar and after some proper heat loss calcs they walk away with requirements much much lower. If the heat loss calc is right, rather than spending money on batteries and solar, put it into improving the building.
jack Posted Wednesday at 11:02 Posted Wednesday at 11:02 13 hours ago, Nickfromwales said: You can’t become huge rush, and @jack has one of their units iirc. Nope, not me. I do look wistfully at their site every couple months. It's utterly insane how much prices have come down over the last few years. 1
-rick- Posted Wednesday at 11:24 Posted Wednesday at 11:24 20 minutes ago, jack said: I do look wistfully at their site every couple months. It's utterly insane how much prices have come down over the last few years. Feels like every time I look the prices are lower and the offerings better. Though I read recently that the Chinese government is stepping in to control the market in China in an effort to stop companies competeing each other into the ground. Same as they did for solar. So thats likely to mean prices stabilise where they are/go up a bit barring significant breakthroughs with batteries (sodium-ion maybe?) 1
Dillsue Posted Wednesday at 13:07 Posted Wednesday at 13:07 14 hours ago, kentar said: It seems Fogstar offer the best bang for buck. 2x 16kwh batteries comes out to £4k. Thats £125/kwh. I don't think there's anyone else who comes close. I'm trying to get to a point of being cost negative. How much money can I generate from this? I don't know what my energy usage will be. Fogstar do 15kwh self assembly kits for £1480 so under £3k for 30kwh and showing in stock. How much money you can generate depends on so many things but you'd need to estimate usage and choose a tariff as a start
JohnMo Posted Wednesday at 13:09 Posted Wednesday at 13:09 1 minute ago, Dillsue said: How much money you can generate depends on so many things but you'd need to estimate usage and choose a tariff as a start And if you have solar, no solar no export payments, unless things have changed in the last 3 months.
Jenki Posted Wednesday at 13:17 Posted Wednesday at 13:17 15 hours ago, -rick- said: If the heat loss calc is right, rather than spending money on batteries and solar, put it into improving the building. 👍This. 1
Nickfromwales Posted Wednesday at 13:50 Posted Wednesday at 13:50 2 hours ago, jack said: Nope, not me. I do look wistfully at their site every couple months. It's utterly insane how much prices have come down over the last few years. Ah yes, just reread that post and you mention them, just my poor brain recalled that you had gone for one. They do seem to be cheap as chips though!
Andehh Posted yesterday at 06:31 Posted yesterday at 06:31 I presume you then need to buy a seperate inverter, which is wired into the fuse box?
Dillsue Posted yesterday at 09:42 Posted yesterday at 09:42 3 hours ago, Andehh said: I presume you then need to buy a seperate inverter, which is wired into the fuse box? If your existing solar inverter is a hybrid version then you can connect batteries to that, but..... if you want the batteries remote from the inverter then you'll need massive cables to carry the high current delivered by the battery if its a low voltage battery, around 48/50volts. If you want the batteries in your garage the probably more cost effective to have a second inverter in the garage to manage the batteries 2
Roger440 Posted 23 hours ago Posted 23 hours ago On 21/01/2026 at 13:07, Dillsue said: Fogstar do 15kwh self assembly kits for £1480 so under £3k for 30kwh and showing in stock. How much money you can generate depends on so many things but you'd need to estimate usage and choose a tariff as a start Are you referring to this? https://www.fogstar.co.uk/blogs/fogstar-blog/lifepo4-diy-battery-builds-made-easier-with-the-seplos-mason-kit?_pos=2&_sid=c779d90ee&_ss=r
Dillsue Posted 21 hours ago Posted 21 hours ago This https://www.fogstar.co.uk/collections/solar-battery-storage/products/seplos-v4-kit-and-x16-highstar-314ah-bundle
Stu789 Posted 20 hours ago Posted 20 hours ago If siting batteries outside you may want to look at insulation within your available space - in general (not vendor specific) they really don't like charging when cold. Also there is supposed to be an efficiency penalty for low voltage batteries (48V) vs high voltage (300+) - I'm considering Fox ESS EP12s which are quite slim and have an inbuilt heater. Good luck and please do post updates/outcome - interested to read!
Andehh Posted 16 hours ago Posted 16 hours ago (edited) 10 hours ago, Dillsue said: If your existing solar inverter is a hybrid version then you can connect batteries to that, but..... if you want the batteries remote from the inverter then you'll need massive cables to carry the high current delivered by the battery if its a low voltage battery, around 48/50volts. If you want the batteries in your garage the probably more cost effective to have a second inverter in the garage to manage the batteries Could I locate batteries and inverter in nearby garage (cable length of around 8m) then utilise the existing armoured cable that runs between garage and fuse box (originally there for a 7kw car charger)? Existing 3kw solar and inverter is tied to a very old and lucrative FIT, so happy to leave that seperate . 😎 Edited 16 hours ago by Andehh
Dillsue Posted 15 hours ago Posted 15 hours ago 52 minutes ago, Andehh said: Could I locate batteries and inverter in nearby garage (cable length of around 8m) then utilise the existing armoured cable that runs between garage and fuse box (originally there for a 7kw car charger)? Existing 3kw solar and inverter is tied to a very old and lucrative FIT, so happy to leave that seperate . 😎 If the cable was correctly sized to carry 7 kw from the house to the garage for the charger then it will be large enough to carry up to 7kw in the other direction ie from the battery inverter to the house. FIT rules changed a few years ago and you can chop and change a system like adding batteries and probably change the inverter for a hybrid if that suited you better 1
Roger440 Posted 14 hours ago Posted 14 hours ago 6 hours ago, Dillsue said: This https://www.fogstar.co.uk/collections/solar-battery-storage/products/seplos-v4-kit-and-x16-highstar-314ah-bundle Thanks. Not the easiest website that one. Unless you are an expert. Seems like a cheap way into batteries.
-rick- Posted 14 hours ago Posted 14 hours ago 1 minute ago, Roger440 said: I might be being dumb, but how are you concluding thats a 15kWh battery? 2 ways: 1. Calculate it. P = I x V. They are using the 16 batteries in series so the 314Ah per cell applies to the whole pack. Therefore, P = 314 x 48 = 15072 = 15kwh * 2. They have a very similar model that is assembled for £500 more and also has better batteries so you can directly compare it to that. https://www.fogstar.co.uk/collections/solar-battery-storage/products/fogstar-energy-16kwh-48v-solar-battery * @Dillsue clearly did the maths with 48V as the voltage, but the specs say the nominal voltage per cell is 3.2V so 16x3.2=51.2V. When you plug this into the power formula you get 16072 which is the same as they claim for the other battery above. 1
Roger440 Posted 14 hours ago Posted 14 hours ago 2 minutes ago, -rick- said: 2 ways: 1. Calculate it. P = I x V. They are using the 16 batteries in series so the 314Ah per cell applies to the whole pack. Therefore, P = 314 x 48 = 15072 = 15kwh * 2. They have a very similar model that is assembled for £500 more and also has better batteries so you can directly compare it to that. https://www.fogstar.co.uk/collections/solar-battery-storage/products/fogstar-energy-16kwh-48v-solar-battery * @Dillsue clearly did the maths with 48V as the voltage, but the specs say the nominal voltage per cell is 3.2V so 16x3.2=51.2V. When you plug this into the power formula you get 16072 which is the same as they claim for the other battery above. Thanks. I was being dumb. Had a "special" moment. Worked it out and deleted the post, but you saw it 30kWh for £3k is starting to make some sense. Assuming i can do the install (inc my PV) myself. Although, i still dont really want to have batteries as its all just more stuff to manage and go wrong. Too much electronics for my liking. Need to re-crunch my payback time. 1
Dillsue Posted 5 hours ago Posted 5 hours ago 8 hours ago, Roger440 said: Need to re-crunch my payback time. Don't spend too much time recrunching as summers only just round the corner and PV£ will be slipping through your fingers😁
