Nickfromwales Posted 11 hours ago Posted 11 hours ago 12 hours ago, MikeSharp01 said: We don't need the immersion to clear the legionnaires risk the heat pump does that. So for now I have wired it straight to the CU breaker via a switch fused unit. So as of now we don't have automation of the immersion but there appears to be nothing preventing me using my contactor approach. The rules are clear that you can put stuff in between those fixed points provided it meets the wiring regs etc which is how the diverters do it. So I won't have any high current stuff on / around the tank other than the connection from Switch Fused Isolator to the immersion heater. Final job is to commission the heat meter & EmonPi. Hopefully Sunday, then I will have some real data to play around with and get an impression for how good or bad the system is. You’re not supposed to use a 13a FCU for a constant 3kw device such as an immersion. You’re supposed to have a 16a breaker and a 20a DP switch as an isolator.
MikeSharp01 Posted 5 hours ago Author Posted 5 hours ago 5 hours ago, Nickfromwales said: ou’re supposed to have a 16a breaker and a 20a DP switch as an isolator. It is, at least that's what I asked for, it doesn't have a fuse anyway.
Nickfromwales Posted 5 hours ago Posted 5 hours ago 18 hours ago, MikeSharp01 said: So I won't have any high current stuff on / around the tank other than the connection from Switch Fused Isolator to the immersion heater. You’re driving me to drink Mike….
MikeSharp01 Posted 5 hours ago Author Posted 5 hours ago 7 minutes ago, Nickfromwales said: You’re driving me to drink Mike… Yes sorry name mix up. To much happening in my world. After 20 years of trouble free service a cistern in one of our bathrooms just cracked without provocation, not been used since Christmas, drowned the router in the stairwell below, left us with no Internet and water everywhere. Sadly its a Fired Earth unit so no guarantee possible- still as I say it has done 20 years. 1
Nickfromwales Posted 5 hours ago Posted 5 hours ago That’s a piss-you-off!! CT1 will get that watertight temporary, if you need to keep using it. Just need to dry it out with a hairdryer and clean it before applying.
