Tide2 Posted December 21, 2025 Posted December 21, 2025 Has anyone experience using or installing these with a gas combi boiler
JohnMo Posted December 21, 2025 Posted December 21, 2025 2 hours ago, Tide2 said: Has anyone experience using or installing these with a gas combi boiler Why would you install with a gas combi? Tell us what you are trying to achieve?
Nickfromwales Posted December 21, 2025 Posted December 21, 2025 1 hour ago, JohnMo said: Why would you install with a gas combi? Tell us what you are trying to achieve? Usually to get higher DHW flow rates, or possibly somewhere to bin off some excess solar PV.
JohnMo Posted December 21, 2025 Posted December 21, 2025 28 minutes ago, Nickfromwales said: Usually to get higher DHW flow rates, or possibly somewhere to bin off some excess solar PV. Maybe simpler to do it upstream of the combi rather than after. Then small amounts of temp rise give massive uplift in flow rate. Combi-SuperFlow-White-Paper-v1-2-4.pdfCanetis-SuperFlow-Product-Sheet-WE-050318.pdf You can also do it way more cheaply than a mini store. As a mini store is based on heating medium in the cylinder and domestic water in the tubes. So you really need to connect the combi to system boiler for the proposed to work.
Nickfromwales Posted December 22, 2025 Posted December 22, 2025 21 hours ago, JohnMo said: Maybe simpler to do it upstream of the combi rather than after. Then small amounts of temp rise give massive uplift in flow rate. Combi-SuperFlow-White-Paper-v1-2-4.pdf 960.61 kB · 12 downloads Canetis-SuperFlow-Product-Sheet-WE-050318.pdf 322.43 kB · 5 downloads You can also do it way more cheaply than a mini store. As a mini store is based on heating medium in the cylinder and domestic water in the tubes. So you really need to connect the combi to system boiler for the proposed to work. You’re still always constrained by the physical max flow rate of water, whatever temp, through a combi.
JohnMo Posted December 22, 2025 Posted December 22, 2025 (edited) 49 minutes ago, Nickfromwales said: You’re still always constrained by the physical max flow rate of water, whatever temp, through a combi. Could get 3 showers out of mine, you take the flow restrictor out, I never installed mine, because I always preheat with upstream preheat, can't do any better with UVC I now have. Edited December 22, 2025 by JohnMo
Nickfromwales Posted December 22, 2025 Posted December 22, 2025 5 hours ago, JohnMo said: Could get 3 showers out of mine, you take the flow restrictor out, I never installed mine, because I always preheat with upstream preheat, can't do any better with UVC I now have. UVC doesn't give higher flow rates at the 50o+ temps? Combi's can't usually be compared. 3 showers is very good, at what flow rates?
Tide2 Posted December 27, 2025 Author Posted December 27, 2025 On 21/12/2025 at 17:36, JohnMo said: Why would you install with a gas combi? Tell us what you are trying to achieve? I want to use solar PV for hot water during the summer months. Also, the cylinder could be sited nearer the main drawoff points, thus avoiding the annoying wait for the water to run hot. I believe this will reduce energy costs, with a modest outlay, with a fairly simple system
JohnMo Posted December 27, 2025 Posted December 27, 2025 21 minutes ago, Tide2 said: modest outlay, £1400 isn't modest in my book. Plus if used the way you are suggesting you would need a full safety group. You may have a few things to resolve. If water flows through the combi it will fire up, so use gas anyway. If heat store isn't heated, sun not playing ball, it would just cool the water already heated by gas boiler. So no hot water! I would install cylinder upstream of the combi, heat by solar, if water is above 45 divert around boiler direct to tap, if below 45 let it be heated by boiler. Saves boiling firing when not needed etc.
Tide2 Posted December 27, 2025 Author Posted December 27, 2025 29 minutes ago, JohnMo said: £1400 isn't modest in my book. Plus if used the way you are suggesting you would need a full safety group. You may have a few things to resolve. If water flows through the combi it will fire up, so use gas anyway. If heat store isn't heated, sun not playing ball, it would just cool the water already heated by gas boiler. So no hot water! I would install cylinder upstream of the combi, heat by solar, if water is above 45 divert around boiler direct to tap, if below 45 let it be heated by boiler. Saves boiling firing when not needed etc. Thanks for the reply "£1400 isn't modest in my book." *Agreed, it's modest compared to a heat pump and solar PV system though "Plus if used the way you are suggesting you would need a full safety group" Not familiar with this term, could you expand please "You may have a few things to resolve" Not sure I follow your logic in this paragraph The cylinder is heated from the heating side of the combi Via a 2 port valve controlled by a cylinder stat. A second 2 port valve valve would be required to allow heating via a room Stat. all this adds complication of course. The hot water side of the combi is not used. The DHW draw is via the the heat exchanger one side being mains fed the other to the taps, as there is very little stored water to be heated in the heat exchanger, way under 15L, so no tundish or discharge pipework required I do like your preheat cylinder idea, not sure it would help with the long draw off time though
JohnMo Posted December 27, 2025 Posted December 27, 2025 If you have the space put a proper UVC in. The mini store is unlikely to perform much better than your combi except immediate draw of would be quicker.
Tide2 Posted December 27, 2025 Author Posted December 27, 2025 9 minutes ago, JohnMo said: If you have the space put a proper UVC in. The mini store is unlikely to perform much better than your combi except immediate draw of would be quicker. I dont like the added complication of the tundish and discharge pipe work in my situation Thanks for your input
Nickfromwales Posted December 27, 2025 Posted December 27, 2025 22 minutes ago, Tide2 said: I dont like the added complication of the tundish and discharge pipe work in my situation Thanks for your input You won't have a choice, if you put an immersion heater into a sealed system.
Tide2 Posted December 27, 2025 Author Posted December 27, 2025 (edited) Thanks for pointing that out. There was no mention of it in the info I looked at, but I did have a concern at the time. Thinking about it, how is it different from the combi input heat, which would be far greater Edited December 27, 2025 by Tide2
Nickfromwales Posted December 27, 2025 Posted December 27, 2025 7 minutes ago, Tide2 said: Thanks for pointing that out. There was no mention of it in the info I looked at, but I did have a concern. Thinking about it how is it different to the combi input which would be far greater The combi is full of weak components and no cylinder, ergo something would just go pop if it ever super-heated the water. Loads of failsafe avenues there. If you heat a sealed cylinder, it becomes a bomb.
Tide2 Posted December 28, 2025 Author Posted December 28, 2025 "If you heat a sealed cylinder, it becomes a bomb". Indeed! "Thinking about it how is it different to the combi input which would be far greater?" Answering my own question,' what I overlooked in this statement, the heated water is already expanded in the boiler and taken care of with its own safety features
JohnMo Posted December 28, 2025 Posted December 28, 2025 The HE mini store, is a part of the central heating system, in it can be included in the already in place expansion vessel (recheck sized based on increased system capacity) and relief valve etc. 21 hours ago, Tide2 said: want to use solar PV for hot water during the summer months Assume ministore has an immersion, it could be heated by that, but will not take much energy depending on the volume. To get the most out of it, you need to set your boiler up to do priority domestic hot water. Which isn't as straightforward with a combi, but can be done. Then you can blast the ministore with high temp (80 Deg) water to ensure you actually have endless DHW in winter and top as needed in summer. Your immersion will hold the temperature while idle, but on hot water draw, will not keep up especially if running on excess PV via a diverter. So get your tin hat ready "the blo@dy hot water cold again" moments with the other half.
