Tide2 Posted 11 hours ago Posted 11 hours ago Has anyone experience using or installing these with a gas combi boiler
JohnMo Posted 8 hours ago Posted 8 hours ago 2 hours ago, Tide2 said: Has anyone experience using or installing these with a gas combi boiler Why would you install with a gas combi? Tell us what you are trying to achieve?
Nickfromwales Posted 7 hours ago Posted 7 hours ago 1 hour ago, JohnMo said: Why would you install with a gas combi? Tell us what you are trying to achieve? Usually to get higher DHW flow rates, or possibly somewhere to bin off some excess solar PV.
JohnMo Posted 6 hours ago Posted 6 hours ago 28 minutes ago, Nickfromwales said: Usually to get higher DHW flow rates, or possibly somewhere to bin off some excess solar PV. Maybe simpler to do it upstream of the combi rather than after. Then small amounts of temp rise give massive uplift in flow rate. Combi-SuperFlow-White-Paper-v1-2-4.pdfCanetis-SuperFlow-Product-Sheet-WE-050318.pdf You can also do it way more cheaply than a mini store. As a mini store is based on heating medium in the cylinder and domestic water in the tubes. So you really need to connect the combi to system boiler for the proposed to work.
