MortarThePoint Posted December 14, 2025 Posted December 14, 2025 (edited) I need to turn 90 degrees from my bottle gully without using an inspection chamber for the turn and see two main options for it: (a) use a 45 degree bend on the bottle gully and then a second 45 bend before the long pipe run (~5m). (b) use a rest bend either directly on the bottle gully or after a coupler and short length of pipe (will depend on trench position). Both should be roddable since the bottle gully can be rodded and there is an Inspection Chamber (I.C.) at the end of the long pipe (~5m). Can't you rod through a rest bend? If so, I lean towards option (b). (b) is also cheaper as I have a spare rest bend. What do others think? For full disclosure, the I.C. is a 4D960 shallow one and has two S/S 45 bends on it as it is at the corner of the house so the pipe turns. All these pipes will be paved over. Edited December 14, 2025 by MortarThePoint correcting 4D563 code
Nickfromwales Posted December 15, 2025 Posted December 15, 2025 Defo overkill to have an IC to do this. Option B is a plenty good enough (normal) solution, afaic. 1 1
Nickfromwales Posted December 15, 2025 Posted December 15, 2025 @MortarThePoint You may need the 2x 45° option if there’s a sudden change in levels. Also, I’m sure most of these square pots drop into a round socket, so you can rotate the pot and the grille stays square to the house.
MortarThePoint Posted December 15, 2025 Author Posted December 15, 2025 9 minutes ago, Nickfromwales said: Also, I’m sure most of these square pots drop into a round socket, so you can rotate the pot and the grille stays square to the house. I'm using a type with a concrete top mould on which I don't think can rotate
Nickfromwales Posted December 16, 2025 Posted December 16, 2025 4 hours ago, MortarThePoint said: I'm using a type with a concrete top mould on which I don't think can rotate 2x 45’s may give you more wriggle room then.
MortarThePoint Posted December 16, 2025 Author Posted December 16, 2025 17 hours ago, Nickfromwales said: 2x 45’s may give you more wriggle room then. If I have a stub and rocker off the rest bend before the long pipe (or stubs either side), it should provide some flexibility to tune the angles and position. That raises the number of seals from 2 (rest bend connected directly to gully and long pipe) to 6.
