Good afternoon,
I’ve lived in my cottage for 12 years (small terrace) and have often wondered how the manual pump could be converted…
I am unsure where the well for the pump is but we suspect it’s approximately 10ft away from the pump. During the summer a circle of grass dries out which we can only suspect is a lid to the well (I intend on finding out one day)
please could someone with the knowledge share if an electric conversion is possible? I’ve searched the internet with not much relating to my needs. I have read about submersible pumps which I don’t think would be suitable due to the unknown network of piping & I’ve read about the potential requirement for a holding tank, something that may not suit a small cottage..
any input is much appreciated.
Many thanks
Hi @Doz, a lot depends on what is underground, well or borehole. Also what you are wanting the water for? And how often.
converting your existing pump isn’t practical, motor, crank connecting to the arm etc. but a submersible or bore hole pump are pretty straight forward and could pup out through your existing fuxture with a bit of modification
