After a bit of advice following a knock through... As you'd expect, there was a DPC atop those concrete blocks in my picture, now removed along with the wall. Next step is making good and I was planning to put a latex compound down to smooth/sort out slight level differences. BUT, without the DPC, I worry about the risk of moisture ingress via capillary action. It's a block and beam floor and those concrete blocks are ultimately in ground contact. What's the most practical way to resolve the risk?
I'm wondering if I might actually be wrong.... In trying to figure the situation out, I've been watching lots of videos about block and beam floors. In every case it seems that a DPC is placed underneath the beams themselves. So, I might be worrying about nothing. If that's the case though, I can't understand why there was  an additional DPC at screed level for the internal walls. This is the same height as the DPC visible on my exterior walls. Maybe a DPC was applied to the internal walls out of an abundance of caution? Am I talking rubbish?
Not many would take the risk of omitting the secondary (industry standard) line of defence; the DPC at floor level.
There are no guarantees with the subfloor DPM/DPC so it’s certainly not an abundance of caution, more a sensible, standard methodology which give you the obligatory belt, and accompanying braces ;)
Do as the Welsh fella says, and you’ll live happily (and dry) ever after.
The end.
