After a bit of advice following a knock through... As you'd expect, there was a DPC atop those concrete blocks in my picture, now removed along with the wall. Next step is making good and I was planning to put a latex compound down to smooth/sort out slight level differences. BUT, without the DPC, I worry about the risk of moisture ingress via capillary action. It's a block and beam floor and those concrete blocks are ultimately in ground contact. What's the most practical way to resolve the risk?
54 minutes ago, JFH777 said:
thanks that's not a bad idea
Just make sure you foam or mastic any gaps either side of the blocks so the SLC doesn’t just disappear down south.
