JFH777 Posted December 10, 2025 Posted December 10, 2025 After a bit of advice following a knock through... As you'd expect, there was a DPC atop those concrete blocks in my picture, now removed along with the wall. Next step is making good and I was planning to put a latex compound down to smooth/sort out slight level differences. BUT, without the DPC, I worry about the risk of moisture ingress via capillary action. It's a block and beam floor and those concrete blocks are ultimately in ground contact. What's the most practical way to resolve the risk?
Nickfromwales Posted December 10, 2025 Posted December 10, 2025 https://www.toolstation.com/everbuild-black-jack-damp-proof-membrane/p10290?store=null&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gad_source=1&gad_campaignid=21016232523&gbraid=0AAAAAD-vLcX3SICQivfTjJrOYFQACEcF9&gclid=CjwKCAiA0eTJBhBaEiwA-Pa-hbx22hKHf4L0JhrXGpuqT5asuMzSUApyYANX_9hicTjUNIoDLEk_zBoCpeYQAvD_BwE I'd chip away an inch or so from the top of those blocks, then apply the liquid DPC, and then after at least 2-3 coats have been applied you can back-fill with a self-levelling compound. You can get 1L tins iirc. 1 1
Nickfromwales Posted December 11, 2025 Posted December 11, 2025 54 minutes ago, JFH777 said: thanks that's not a bad idea Just make sure you foam or mastic any gaps either side of the blocks so the SLC doesn’t just disappear down south.
JFH777 Posted December 11, 2025 Author Posted December 11, 2025 I'm wondering if I might actually be wrong.... In trying to figure the situation out, I've been watching lots of videos about block and beam floors. In every case it seems that a DPC is placed underneath the beams themselves. So, I might be worrying about nothing. If that's the case though, I can't understand why there was an additional DPC at screed level for the internal walls. This is the same height as the DPC visible on my exterior walls. Maybe a DPC was applied to the internal walls out of an abundance of caution? Am I talking rubbish?
Big Jimbo Posted December 11, 2025 Posted December 11, 2025 Do as @Nickfromwales advised. We cant tell if that wall has been built off the B and B, or off the foundations. Spend £30 and have it sorted. 1
Nickfromwales Posted December 11, 2025 Posted December 11, 2025 1 hour ago, JFH777 said: I'm wondering if I might actually be wrong.... In trying to figure the situation out, I've been watching lots of videos about block and beam floors. In every case it seems that a DPC is placed underneath the beams themselves. So, I might be worrying about nothing. If that's the case though, I can't understand why there was an additional DPC at screed level for the internal walls. This is the same height as the DPC visible on my exterior walls. Maybe a DPC was applied to the internal walls out of an abundance of caution? Am I talking rubbish? Not many would take the risk of omitting the secondary (industry standard) line of defence; the DPC at floor level. There are no guarantees with the subfloor DPM/DPC so it’s certainly not an abundance of caution, more a sensible, standard methodology which give you the obligatory belt, and accompanying braces Do as the Welsh fella says, and you’ll live happily (and dry) ever after. The end. 1
