Two year old system, serviced annually has repeatedly shutdown with E911 error code.
ASHP filter has been cleaned of debris 3 times (non ferrous).
any ideas why this keeps happening every 3-4 days.
thanks in advance.
Paul
photo attached
Your system looks manky.
Delete the strainer and install a proper filter is step one.
Is system correctly inhibited? Not a fan of glycol if your system is filled with that. If not needs a suitable inhibitor and if a low temp system biocide.
  • jack changed the title to Samsung/Gen6 plumbed boiler (ASHP)
I can't help with your question, but I've moved it to the ASHP sub-forum and mentioned that it's an ASHP in the title (I would generally assume a "boiler" is gas or oil fired).
