Potatoman Posted 4 hours ago Posted 4 hours ago Hi, I would like to fit a 28 mm fill and flush valve to my system, but the valve reduces the bore to about 20mm for about 35mm in length, will this have any effect on the flow/ efficiency of my system. Thanks
JohnMo Posted 3 hours ago Posted 3 hours ago 1 hour ago, Potatoman said: Hi, I would like to fit a 28 mm fill and flush valve to my system, but the valve reduces the bore to about 20mm for about 35mm in length, will this have any effect on the flow/ efficiency of my system. Thanks A little, or a lot depending on flow rates, if your at 20L/min and below very little, higher rates a bigger and bigger influence - if you have UFH you can do this at the manifold anyway. So wouldn't bother, unless you have a good reason.
