allthatpebbledash Posted November 26, 2025 Posted November 26, 2025 (edited) Thinking about wood flooring and really appreciate the look of the Dinesen products. Even more interesting are the lengths (and widths) of their offerings. The solid planks can go up to 6m and beyond. Their engineered “layers” range can also run to 5m odd. What’s not interesting is the cost of them. Are their alternatives of engineered wood flooring that can span lengths of 5-6m at least to give a seamless floor look of running lengths of wood? I don’t like the idea of a vertical line being broken up by 2 or more pieces. The longest length of any room I have is going to be 6m so I can get away with having a break at one end possibly where it’ll be unnoticeable in the large open area. Every other room will just have a seamless liner look though if 5m lengths can be achieved. Quick google search shows there’s a few wider plank offerings but can’t find any longer than 3m. Any suggestions? Edited November 26, 2025 by allthatpebbledash Spellings
Gus Potter Posted November 27, 2025 Posted November 27, 2025 Yes, treat all this with a big pinch of salt, check their fine print. You must look at their technical spec, the range of moisture content, expansion edge gaps and so on and make sure that the way you want to live fits. In other words, say you bail out to Spain in the winter and turn the heating low.. or rent it out and folk dry their washing!
