MortarThePoint Posted November 26 Posted November 26 I'm about to lay lots of 110mm drainage pipe and wondered if there is some effective protection I can put in to prevent root penetrating the ring seals. Ideally it would be something I can wrap around the joint. Has anyone identified a good approach. Osma have something new called Rootseal. No idea if it works and it is only on newly bought Osma fittings and I have a lot of older black ring fittings.
Oz07 Posted November 26 Posted November 26 They only find the joints if it leaks surely? Just make a good job you should be fine. 1
MortarThePoint Posted November 26 Author Posted November 26 4 minutes ago, Oz07 said: Just make a good job you should be fine That's the plan, but you never know 1
MortarThePoint Posted Thursday at 07:38 Author Posted Thursday at 07:38 (edited) I can find geotextile sleeves designed to stop silt and sand entering land drain pipes, but not one designed to sleeve over pipe couplings to stop root penetration. Three approaches I am considering are: Do nothing Wrap and cable tie each coupling with a 1m length of non-woven geotextile like this: https://www.amazon.co.uk/dp/B0DQ88WHD4/?th=1 Use a 1m length 8" temporary downpipe or layflat tubing an duct tape at each coupling (normal 150mm not large enough) I found this but not UK: https://www.mainlinematerials.com/products/underground-pipe-root-barrier Edited Thursday at 08:03 by MortarThePoint
MortarThePoint Posted Thursday at 08:18 Author Posted Thursday at 08:18 Actually, the socket OD of the couplers is just too big for 8" layflat tubing so would need to be 10" or larger: https://www.amazon.co.uk/Triplast-LF5001001-10-Inch-Layflat-Tubing/dp/B07BRNYC32/
Oz07 Posted Friday at 15:28 Posted Friday at 15:28 On 27/11/2025 at 07:38, MortarThePoint said: I can find geotextile sleeves designed to stop silt and sand entering land drain pipes, but not one designed to sleeve over pipe couplings to stop root penetration. Three approaches I am considering are: Do nothing Wrap and cable tie each coupling with a 1m length of non-woven geotextile like this: https://www.amazon.co.uk/dp/B0DQ88WHD4/?th=1 Use a 1m length 8" temporary downpipe or layflat tubing an duct tape at each coupling (normal 150mm not large enough) I found this but not UK: https://www.mainlinematerials.com/products/underground-pipe-root-barrier Option 1
