MortarThePoint Posted November 26, 2025 Posted November 26, 2025 I'm about to lay lots of 110mm drainage pipe and wondered if there is some effective protection I can put in to prevent root penetrating the ring seals. Ideally it would be something I can wrap around the joint. Has anyone identified a good approach. Osma have something new called Rootseal. No idea if it works and it is only on newly bought Osma fittings and I have a lot of older black ring fittings.
Oz07 Posted November 26, 2025 Posted November 26, 2025 They only find the joints if it leaks surely? Just make a good job you should be fine. 1
MortarThePoint Posted November 26, 2025 Author Posted November 26, 2025 4 minutes ago, Oz07 said: Just make a good job you should be fine That's the plan, but you never know 1
MortarThePoint Posted November 27, 2025 Author Posted November 27, 2025 (edited) I can find geotextile sleeves designed to stop silt and sand entering land drain pipes, but not one designed to sleeve over pipe couplings to stop root penetration. Three approaches I am considering are: Do nothing Wrap and cable tie each coupling with a 1m length of non-woven geotextile like this: https://www.amazon.co.uk/dp/B0DQ88WHD4/?th=1 Use a 1m length 8" temporary downpipe or layflat tubing an duct tape at each coupling (normal 150mm not large enough) I found this but not UK: https://www.mainlinematerials.com/products/underground-pipe-root-barrier Edited November 27, 2025 by MortarThePoint
MortarThePoint Posted November 27, 2025 Author Posted November 27, 2025 Actually, the socket OD of the couplers is just too big for 8" layflat tubing so would need to be 10" or larger: https://www.amazon.co.uk/Triplast-LF5001001-10-Inch-Layflat-Tubing/dp/B07BRNYC32/
Oz07 Posted November 28, 2025 Posted November 28, 2025 On 27/11/2025 at 07:38, MortarThePoint said: I can find geotextile sleeves designed to stop silt and sand entering land drain pipes, but not one designed to sleeve over pipe couplings to stop root penetration. Three approaches I am considering are: Do nothing Wrap and cable tie each coupling with a 1m length of non-woven geotextile like this: https://www.amazon.co.uk/dp/B0DQ88WHD4/?th=1 Use a 1m length 8" temporary downpipe or layflat tubing an duct tape at each coupling (normal 150mm not large enough) I found this but not UK: https://www.mainlinematerials.com/products/underground-pipe-root-barrier Option 1
