Jothetaxi Posted November 20 Posted November 20 (edited) We're having Lutron RA2 Select set up for our lighting system. The electrician has a lighting plan showing a circuit for a dimmable LED tape in a media unit. The LED tape will be connected to the RA2 select using the 0-10v dimming module. The electrician says this can work via the 5 amp socket, but i'm a bit confused by this - would it have to plug in? The media unit is free standing so I thought a cable would be required for the connection to the media unit. I'm waiting for him to come back to me but thought I would ask here as well. Thanks. Edited November 20 by Jothetaxi
Nickfromwales Posted November 21 Posted November 21 On 20/11/2025 at 18:06, Jothetaxi said: We're having Lutron RA2 Select set up for our lighting system. The electrician has a lighting plan showing a circuit for a dimmable LED tape in a media unit. The LED tape will be connected to the RA2 select using the 0-10v dimming module. The electrician says this can work via the 5 amp socket, but i'm a bit confused by this - would it have to plug in? The media unit is free standing so I thought a cable would be required for the connection to the media unit. I'm waiting for him to come back to me but thought I would ask here as well. Thanks. Is it RGBW / RGB / CCT?
