-rick- Posted December 19, 2025 Posted December 19, 2025 23 hours ago, Dan F said: Yes, during the day downlights are 3000k and LED's 6500k. I could have it set up so LED's never go past 3000K, but in some rooms it's nice to have more daylight color temperature during the day. Depending on the need for task-lighting, and if the light-level, I have just LED, just downlights of both on during the day. So do you notice the mismatched colour? 23 hours ago, Dan F said: Most rooms have evening/night mood which is just LED, or mostly LED with downlights on min filling in shadows, but this can all be adjust based on what works best based on room and preferences. Would you mind sharing a photo or two? You are clearly happy with things, but I've never got on with mixed colour temps in the same space though because I've always been careful I've never lived with it, just noticed in other places so I'm really curious to see if it can be made to work with careful application.
lookseehear Posted December 24, 2025 Posted December 24, 2025 I’m looking at using ‘dim to warm’ bulbs which get warmer as they get dimmer, meaning you can get controllable white temperature but without from a regular dimmer switch. my current plan is to put zigbee dimmer controllers behind retractable push button switches so that they function as regular dimmable lights but with the option to create scenes as well. 1
