vala Posted October 25 Posted October 25 Had an extension at front of the house for a utility/wc and a new soil pipe was installed which connects into the existing. The run consists of a 1m straight, 90° bend, followed by a 8-9m straight before connecting into the existing drain. This has been installed for a toilet, basin, washing machine/tumble dryer. Does this need to be vented separately to the original/main stack?
Nickfromwales Posted October 25 Posted October 25 8 minutes ago, vala said: Had an extension at front of the house for a utility/wc and a new soil pipe was installed which connects into the existing. The run consists of a 1m straight, 90° bend, followed by a 8-9m straight before connecting into the existing drain. This has been installed for a toilet, basin, washing machine/tumble dryer. Does this need to be vented separately to the original/main stack? No, it doesn't. If the invert (drop from one end to the other) is <1300mm then you don't even need and AAV (air admittance valve, aka a "Durgo"), so all I would do is make the 90 bend an inspection bend LINK so you can rod down the 8-9m run, and back into the 1m run for self-maintenance.
vala Posted October 26 Author Posted October 26 12 hours ago, Nickfromwales said: No, it doesn't. If the invert (drop from one end to the other) is <1300mm then you don't even need and AAV (air admittance valve, aka a "Durgo"), so all I would do is make the 90 bend an inspection bend LINK so you can rod down the 8-9m run, and back into the 1m run for self-maintenance. Perfect. Thanks for the confirmation @Nickfromwales and yes already installed an inspection chamber over the 90° bend. 1
