Strangey71 Posted October 17, 2025 Posted October 17, 2025 Hi everyone We are placing a log burner in a big hearth that is brick and mortar now as I removed all plaster and cleaned for ascetic purposes, could someone recommend a heat resistant SBR or Brick and dust sealer thats Heat resistant or suitable for this. Is ordinary SBR any good for this?
saveasteading Posted October 17, 2025 Posted October 17, 2025 A new burner should not emit too much heat to the sides, or through an insulated flue. If it's an old burner then it won't meet regulations so I will be careful not to encourage misuse. Eg insulated flue, chimney liner, air intake. I didn't know what SBR was but looked it up. Does the brickwork need coating or protecting? Is the SBR to be a coating or a mortar additive?
Strangey71 Posted October 18, 2025 Author Posted October 18, 2025 (edited) Hiya, its just to be a coating and its a new log burner all installed to spec by heats engineer, 10kw Charnwood, its just to stabilise the bricks and mortar dust, I know they wont burn just didn't want something that was going to emit toxins, I don't think they will but double checking to see if anyone has used or knows the answer? Edited October 18, 2025 by Strangey71
SteamyTea Posted October 18, 2025 Posted October 18, 2025 Styrene Butadiene Rubber, which is SBR has quite a high melting point, so should be able to handle 100°C for quite a long times. If it is mixed in with a render, then thermal creep should not be a problem, if as a coating, then it may soften and move. Why has it been suggested that SBR is added, it is usually as a waterproofing agent. Always best to avoid combustion inside a building, so anyway you can ditch the burner.
