Dement0r Posted October 14 Posted October 14 (edited) Hi there I am looking for advice please. We live in a 1950s council house in Lincolnshire, and we're looking at mounting an aerial rig in our front room for our 8 year old daughter. She currently weighs approx. 26kg and will be doing aerial hoop and silks like in this video https://www.youtube.com/watch?v=rsm3YNWAs9k Our proposed solution is to put a 2630mm, 42.4mm galvanised steel tube wall-to-wall, secured with M6x75 concrete bolts, as shown in the images here https://photos.app.goo.gl/aetVwKYPtDNSzSUT8. The blue wall is a supporting interior brick wall. My main concern is the other side, where the bay window is. My understanding is that this is steel reinforced concrete lintel. I am concerned that these are obviously designed to hold a static load, however obviously the aerial rig will have a lot of movement, and I am wondering whether it will be suitable to mount the steel bar in the brickwork above, or if we risk damaging the structural integrity of our house? Thanks you in advance Edited October 14 by Dement0r
Redbeard Posted October 16 Posted October 16 Sorry I am the first to chime in. I think you need a Structural Engineer and an 'invasive survey' (expose enough of the lintel to see exactly what it is so the SE can calculate - not guess.) My (definitely non-SE) feeling would be that whatever dead load that lintel is designed for it was not designed for the live load you refer to.
Nickfromwales Posted November 3 Posted November 3 On 14/10/2025 at 09:10, Dement0r said: Hi there I am looking for advice please. We live in a 1950s council house in Lincolnshire, and we're looking at mounting an aerial rig in our front room for our 8 year old daughter. She currently weighs approx. 26kg and will be doing aerial hoop and silks like in this video https://www.youtube.com/watch?v=rsm3YNWAs9k Our proposed solution is to put a 2630mm, 42.4mm galvanised steel tube wall-to-wall, secured with M6x75 concrete bolts, as shown in the images here https://photos.app.goo.gl/aetVwKYPtDNSzSUT8. The blue wall is a supporting interior brick wall. My main concern is the other side, where the bay window is. My understanding is that this is steel reinforced concrete lintel. I am concerned that these are obviously designed to hold a static load, however obviously the aerial rig will have a lot of movement, and I am wondering whether it will be suitable to mount the steel bar in the brickwork above, or if we risk damaging the structural integrity of our house? Thanks you in advance If this is an installed system, the installers would come and survey this and underwrite the whole thing. They will have done this a thousand times, so unless you’re DIY’ing it the information here would maybe be of not much use to you, sorry. Are you paying contractors to supply and fit, for eg is it coming via a grant / funding?
