RWH Posted October 7, 2025 Posted October 7, 2025 Hello all, Wondering if anyone has experience with AC in relation to soundproofing and could offer any opinion on this? In short, I have a small detached outbuilding that is about 15sqm. I need to install air conditioning somehow but sound proofing is an important consideration, as the space is a noisy workshop that has been soundproofed quite extensively. I need to do this myself, so nothing that requires a gas engineer etc. I have a single room MHRV (Blauberg) that services the room for supply and extract. This did let some sound escape but of course I need to breath and not turn into a mushroom. The MHRV extracts to an alleyway that faces a tall concrete block wall, which is then the neighbours substantial outbuilding (3 stories! Mole people...), then a back access track to the other properties, so in short any noise is sent away from people's homes. The building is recently renovated as a room within a room structure, thick (45mm?) triple glazing, double 54mm solid firedoor (so you open one, then open another), and I am pleased with the overall performance. I never wish to move acoustic plasterboard again. I've looked at the split, pre gassed units, as the hole requires seems smaller - you are just ducting the electrics and copper gas line? So presumably this would sent less noise from inside the building to outside. However, it does mean having a large unit outside, which itself isn't quiet, they seem to he 50db+ - not awful, but probably enough to annoy people if running all day in a heat wave. I've seen the single unit wall mounted versions like the electriQ iQool, that has 2 vent holes going outside, but sits snuggly up to the wall. I have no personal experience with any AC, so again, wondering how much sound may travel? There are also the portable ones which would require a larger vent hole, so presumably would allow more noise to escape. However, with either of the vented ones, there is the possibility of creating some sort of maze ducting, although I don't know how hot, wet air would enjoy that longer term. Any opinions on this would be greatly appreciated! As whatever option I do, it would be a not inconsiderably amount of money and effort. Thank you 🙏
SteamyTea Posted October 7, 2025 Posted October 7, 2025 Hello again. Interesting problem. Is the raise in temperature caused by workshop activity, or climate forcings?
saveasteading Posted October 7, 2025 Posted October 7, 2025 5 hours ago, RWH said: creating some sort of maze ducting, That's the answer. sound doesn't go round corners unless bouncing repeatedly. Make a plenum of plywood at the entrance to your ducting, with your maze within it, and line it with insulating board (rockwool sort of thing. or carpet_ and that should sort it. Keep it bigger than the duct and that won't reduce airflow either.
