Hi all, finally decided to get electric connected to our house, been using a lister generator.
Power company is charging a stupid amount to run electric to the house, but not doing the meter & box, or installation into the house.
I'll get an electrician to do the work but any advice before would be appreciated, the main questions I've got are ;
What are the regulations about a trench for the cable from the road to the meter box ?
What meter/ box is best, surface mount or fit into wall, any recommended ?
Can we run the cable thru the ceiling void and then bring down to the wall to the consumer box or do we need ugly trunking running across the ceiling ?
Thanks for any advice
Thanks for the info, the only thing not answered is about running the cable thru the ceiling void or if trunking is needed across the ceiling ?
Meter tails don’t need to be exposed however if it’s more than 3m from the meter to the consumer unit you need a fused switch at the meter end and an isolator at the CU.  My meter is 27m from the CU..!
