Concrete blocks are 95mm actual width, faced blocks are 100mm actual width.
So how do you position the 100mm faced block wall onto the 95mm footing ?
Edited by Spinny
And the acceptable tolerance from plumb on a 4m high wall which is 7m long ?
(I am seeing something suggesting +/-10mm over 2.5m height, and +/-10mm over a 5m length ?)
Would seem to suggest it would not be hard to be out by 15mm over such a wall ?
Edited by Spinny
