Ahad Posted September 14, 2025 Posted September 14, 2025 We are in the process of renovating an 1820s townhouse. Having a nightmare trying to line up a lime plasterer. Front elevation is double skin brick without a cavity, facing pretty much due South. What would be the consequences of going down the gypsum route for the internal plaster? We’ve managed to safe the original lime on almost all of the other external walls.
nod Posted September 14, 2025 Posted September 14, 2025 If the original lime is skimmed with putty lime It will look exactly the same as gypsum
Ahad Posted September 16, 2025 Author Posted September 16, 2025 Our builder seems convinced that we’d end up with damp and problems down the line….
Mr Punter Posted September 16, 2025 Posted September 16, 2025 If the brickwork is getting saturated you could treat it externally with a coat of StormDry.
