JCL Posted August 29 Posted August 29 Hi all, we are converting a steel frame cattle shed. We have had class q, further more full planning for material amendments. On our plans we have stone to the bottom of the windows, then timber clad above. (Stone work works to be 50sqm we have 40sqm of glass and 140sqm of timber cladding. Being a chippy, i have built all the timber frame on site between the steels as per plans, and sheeted off with tf200. windows are in, works inside currently being carried out. originally the stone was to be built using the sure cav 50 system up to the bottom of the windows, capped with a 200mm slate cill, followed by cladding above (average 2.9 above including the gables) so the water run off from the face of cladding runs onto the cill. questions i have, What do you all think about allot of cladding on a house, will it effect values? we like it but was going to use accoya with its warranty… I would like to add more stone work to finish it at the top of the windows, do away with the slate cill, and pack out the timber frame so to then bring the cladding then over the face of the stone… but would have to pack 175mm or so to get it past the stone face and sure cav. (surecav 50 & 4”cut stone) Thanks in advance.
JohnMo Posted August 29 Posted August 29 As you have approved drawings, wouldn't you have to build to those or go for an amendment? 10 minutes ago, JCL said: allot of cladding on a house, will it effect value Why would it? If it does we are stuffed, but do I care - no. House wouldn't look the same or as nice with a different finish.
JCL Posted August 29 Author Posted August 29 (edited) . Edited August 29 by JCL Wring reply from me —- please see next
JohnMo Posted August 29 Posted August 29 Just now, JCL said: Fair comment 😁 i would never change the cladding i just wondered if too much was too much wood. What kinda cladding have you gone for? Scottish larch.
JCL Posted August 29 Author Posted August 29 John mo- i am not sure! Same material, just slightly higher 🤔 i wouldn’t think planning would worry but its build regs maybe..
JohnMo Posted August 29 Posted August 29 2 hours ago, JCL said: John mo- scottish larch. Nice! Whole house clad in it? To quote someone, so they get notified, you type '@' then start typing the name, a dropdown list appears and you choose the person. Whole front, one end and a full height gable on the rear. The rest is stone slips.
Alan Ambrose Posted August 29 Posted August 29 >>> i wouldn’t think planning would worry It only takes one difficult neighbour to make a complaint. Ours certainly would 😄. There have been some concerns here on 't 'ub that some insurers have limits on the % of cladding they're willing to insure.
JCL Posted August 29 Author Posted August 29 @JohnMo thank you for your help. I am new to the build hub. It sounds nice what you are doing. Keep it up. Thank you for your help.
JCL Posted August 29 Author Posted August 29 @Alan Ambrose haha, yeh.. the neghbours! Lucky my neighbours are my cows, and my mother so were skrewed, all seriousness.. i think a phone call to self build mortgage gang & to the building control officer.
