andyscotland Posted August 28, 2025 Posted August 28, 2025 Hey, I am getting towards finishing (in one room at least 🤣).  I have fermcaell on two external walls (part of a fire resistant buildup) and plasterboard on two internal walls and the ceiling.  I'm planning to skim the plasterboard.  Wondering what's the best way to fill & join the joints between the fermcaell and the PB.  Should I use fermcaell joint filler and paper tape?  Or normal joint filler (Easifill/Knauf/etc) and paper tape?  Or...?  I understand the fermcaell Fine Surface Treatment is very thin - if I use tape on the joints will it be able to cover/hide it? Or would I be better off skimming the fermcaell as well to get a neat finish?  Questions questions! 🤣  Thanks!
nod Posted August 28, 2025 Posted August 28, 2025 Tape all of it with fibre tape Paper tends to lift with plaster finish Use gypsum NOIt filler tgen joint cement Easifil is no good for tapingÂ
andyscotland Posted August 28, 2025 Author Posted August 28, 2025 Thanks @nod - and then Fine Surface Treatment over the filler & boards on the fermcaell sides? Will that hide the tape ok?
