Spinny Posted August 8, 2025 Posted August 8, 2025 Thinking of using surface mounted plastic back boxes but then having them plastered in. So say a 25mm back box with half covered by plaster and half protruding from the wall. Any issue with doing this ? (Will be out of sight under a worktop and avoid cutting into a single skin brick wall)
Nickfromwales Posted August 8, 2025 Posted August 8, 2025 4 minutes ago, Spinny said: Thinking of using surface mounted plastic back boxes but then having them plastered in. So say a 25mm back box with half covered by plaster and half protruding from the wall. Any issue with doing this ? (Will be out of sight under a worktop and avoid cutting into a single skin brick wall) Perfectly fine.
