Spikeuk Posted June 23, 2025 Posted June 23, 2025 (edited) Hi we have had a new extension built and at the point of needing the downstairs floor screeded - i would like to know a rough estimate I should expect this job to cost. The floor area to be screeded in total is 57.5 sq. meters. We have concrete sub base with 10mm cellotex on top, and then underfloor heating running in special plastic trays. There is cellotext thin edge (like skirting board) around the whole permitted to be screeded- I believe this is required when screeding over underfloor heating - for expansion? Domestic use - I've been told it will be dry screed I require, doesn't need to be particularly deep - I think 65mm - currently am in the process of getting quotes, what's a reasonable cost I should expect to a pay a builder for screeding this floor including labour - there is no rush for it drying fast. Thank you in advance. Edited June 23, 2025 by Spikeuk
nod Posted June 23, 2025 Posted June 23, 2025 I laid my own screed So not sure about labour I paid £13 m2 So £800 plus labour 2 men an easy day £600 If it’s a company £1000 Guestinate
Nickfromwales Posted June 23, 2025 Posted June 23, 2025 2 hours ago, Spikeuk said: We have concrete sub base with 10mm cellotex on top Did you mean to say 100mm of insulation? 65mm for dry screed is the minimum thickness I would use dry screed at over insulation, and we've only done thinner where it can be bonded down with a specialist primer. Have you not considered Cemfloor liquid cementitious screed?
Redbeard Posted June 23, 2025 Posted June 23, 2025 What U value have you been quoted for the floor? Is the Perimeter/Area ratio fairly low?
Spikeuk Posted June 24, 2025 Author Posted June 24, 2025 I'm not sure on the U value ill work this out, and yes I did mean to say 100mm celotex. My regular builder has now quoted me £5K - but this includes the 100mm Celotex he has already laid to this floor. ( the underfloor heating has been billed separately.) at 5k - this sounds excessive?. For laying Celotex - I did some quick math- it should be 20 large sheets of Celotex to cover 57.5m2 @ approx £36 per sheet which is 720 - so about £1000 at the very most? meaning its still £4k for the screed.
Nickfromwales Posted June 24, 2025 Posted June 24, 2025 1 hour ago, Spikeuk said: I'm not sure on the U value ill work this out, and yes I did mean to say 100mm celotex. My regular builder has now quoted me £5K - but this includes the 100mm Celotex he has already laid to this floor. ( the underfloor heating has been billed separately.) at 5k - this sounds excessive?. For laying Celotex - I did some quick math- it should be 20 large sheets of Celotex to cover 57.5m2 @ approx £36 per sheet which is 720 - so about £1000 at the very most? meaning its still £4k for the screed. Supply and fit of the insulation prob more towards £1500 with labour? So screed more like £3500? Don't forget your builder will be putting OH+P costs on top of these works.
