For the last 10 years we’ve had a sail over the area but they don’t last long (2 years at best) and the water run off in a downpour soaks the walls so we tried a mesh one which was better for not soaking the walls but not great for sitting under it when it rains
Bought a pergola from a well known brand and it got delivered this week - today the plan is dodge the showers and see if I can get it installed
un-packing the seven boxes took a while
Then clear the area ready to start
No written destructions are supplied - no packing list - apparently I have to download an app and watch a video and we all ignore destructions anyway so how hard can it be!!!!
39 minutes ago, JohnMo said:
Will watch with interest - my next project apparently.
it’s been on Mrs Alien’s list of “things I want” for a while
so far I’ve got two legs assembled 🙂
The video “suggests” doing the wall mount next - so I’m going to ignore that - the decked area has a fall on it for drainage so the “suggested” height might not be right for the location (I already know one of the legs is gonna be in the middle of my garage side door so l’ll need to get creative there (3m x 3m)
cardboard is 3m from mounting wall hahahaIMG_5735.thumb.jpeg.78aaa322306888607e306e4345245ee0.jpeg
44 minutes ago, JohnMo said:
Those pesky gutters
clearance achieved
Finished height will be above them
wall mount end is the tricky bit
I have to fit a 3000 mm width pergola in a 3070 mm gap and there is a 68 mm drainpipe there too
I knew it was gonna be snug but I’ll find a way to make it work
The intention is to have no legs  touching the decking (shortened to minimum and then wall mounted is the plan)
I can shorten the legs without voiding the warranty but I can’t make any alterations to the roof section without losing the warranty
Wall mount / spacer complete
yes it took me all day - I’m a measure 100 times drill or cut once kinda guy (plus manhandling the beams on your own is hard bloody work)
Mrs Alien is 4 ft 10 in socks and has the lifting abilities/strength of a small hen
Doubled up beam both are 2940 x  170 x 45 mm in new money.
First one bolted to the wall in 4 places with 12 x 100 mm thro bolts.
Second beam coach bolted thro both with M8 coach bolts. Now I’ve got clearance for the down-pipe behind the pergola wall mount.
Next I need to find some willing friends - it is a three man lift and there still isn’t a lot of wiggle room….
Might be a few days before I start back on it
surgery I’ve been waiting 2 - 3 years for
I reckon @JohnMo will have his finished before mine 🙂
1 hour ago, JohnMo said:
That looks like it may hurt a bit.
Anaesthetic hasn’t worn off yet so currently no pain at all - pretty sure that will change soon
  • 3 weeks later...
I wasn’t wrong either @JohnMo has finished his
finally found a picture of the normal sail arrangement
at the weekend supported the side rails (once I had both sides level) and then removed the front and legs
shortened the legs and modified the foot plates.
next task make the support brackets
  • 1 month later...
This has taken a while……
Support brackets fabricated in 5mm stainless steel then welded up
Fitted them and was very pleased with the overall look
Mrs Alien not so happy…..
so I sent them off to be powder coated in white to match
now fitted
And the other side
you won’t actually see much of them
the first one will be almost covered by the garage fascia board and gutter
the second one by a water removal pipe stopping it draining onto the decking
better finish the rest of it now
Really cool! I like it, and much neater then the sail.
Please keep us updated! We have a similar alcove that would work well for an identical setup....
Thank you - I hope you have a little more clearance in your alcove than I had 🙂 you really do need a bit more than 70mm for wiggle room!!!
Well bar a little bit of trimming work it’s done
Louvres shut
Louvres open
suns gone and it’s cloudy so light isn’t the best for photos
need to re-instate gutters and fascia and sort out the drainage but quite happy how it turned out - It was never going to be a quick job and limboing round a post parked smack in the middle of the garage side door would have been awful
  • Like 3
