marshian Posted June 7 Posted June 7 Current area For the last 10 years we’ve had a sail over the area but they don’t last long (2 years at best) and the water run off in a downpour soaks the walls so we tried a mesh one which was better for not soaking the walls but not great for sitting under it when it rains Bought a pergola from a well known brand and it got delivered this week - today the plan is dodge the showers and see if I can get it installed un-packing the seven boxes took a while Then clear the area ready to start No written destructions are supplied - no packing list - apparently I have to download an app and watch a video and we all ignore destructions anyway so how hard can it be!!!!
marshian Posted June 7 Author Posted June 7 39 minutes ago, JohnMo said: Will watch with interest - my next project apparently. it’s been on Mrs Alien’s list of “things I want” for a while so far I’ve got two legs assembled 🙂
marshian Posted June 7 Author Posted June 7 The video “suggests” doing the wall mount next - so I’m going to ignore that - the decked area has a fall on it for drainage so the “suggested” height might not be right for the location (I already know one of the legs is gonna be in the middle of my garage side door so l’ll need to get creative there (3m x 3m) cardboard is 3m from mounting wall hahaha
marshian Posted June 7 Author Posted June 7 44 minutes ago, JohnMo said: Those pesky gutters clearance achieved Finished height will be above them wall mount end is the tricky bit I have to fit a 3000 mm width pergola in a 3070 mm gap and there is a 68 mm drainpipe there too I knew it was gonna be snug but I’ll find a way to make it work
marshian Posted June 7 Author Posted June 7 The intention is to have no legs touching the decking (shortened to minimum and then wall mounted is the plan) I can shorten the legs without voiding the warranty but I can’t make any alterations to the roof section without losing the warranty
marshian Posted June 8 Author Posted June 8 Wall mount / spacer complete yes it took me all day - I’m a measure 100 times drill or cut once kinda guy (plus manhandling the beams on your own is hard bloody work) Mrs Alien is 4 ft 10 in socks and has the lifting abilities/strength of a small hen Doubled up beam both are 2940 x 170 x 45 mm in new money. First one bolted to the wall in 4 places with 12 x 100 mm thro bolts. Second beam coach bolted thro both with M8 coach bolts. Now I’ve got clearance for the down-pipe behind the pergola wall mount. Next I need to find some willing friends - it is a three man lift and there still isn’t a lot of wiggle room…. 1
marshian Posted June 11 Author Posted June 11 Lift planned for tomorrow a little more clearance created today
marshian Posted June 11 Author Posted June 11 And done……. well the big lift is done rest is down to me 1
marshian Posted June 13 Author Posted June 13 Might be a few days before I start back on it surgery I’ve been waiting 2 - 3 years for I reckon @JohnMo will have his finished before mine 🙂
marshian Posted June 13 Author Posted June 13 1 hour ago, JohnMo said: That looks like it may hurt a bit. Anaesthetic hasn’t worn off yet so currently no pain at all - pretty sure that will change soon
marshian Posted June 30 Author Posted June 30 I wasn’t wrong either @JohnMo has finished his finally found a picture of the normal sail arrangement at the weekend supported the side rails (once I had both sides level) and then removed the front and legs shortened the legs and modified the foot plates. next task make the support brackets
marshian Posted August 20 Author Posted August 20 This has taken a while…… Support brackets fabricated in 5mm stainless steel then welded up Fitted them and was very pleased with the overall look Mrs Alien not so happy….. so I sent them off to be powder coated in white to match now fitted And the other side you won’t actually see much of them the first one will be almost covered by the garage fascia board and gutter the second one by a water removal pipe stopping it draining onto the decking better finish the rest of it now 1
Andehh Posted August 20 Posted August 20 Really cool! I like it, and much neater then the sail. Please keep us updated! We have a similar alcove that would work well for an identical setup.... 1
marshian Posted August 20 Author Posted August 20 1 hour ago, Andehh said: Really cool! I like it, and much neater then the sail. Please keep us updated! We have a similar alcove that would work well for an identical setup.... Thank you - I hope you have a little more clearance in your alcove than I had 🙂 you really do need a bit more than 70mm for wiggle room!!!
marshian Posted Saturday at 17:42 Author Posted Saturday at 17:42 Well bar a little bit of trimming work it’s done Louvres shut Louvres open suns gone and it’s cloudy so light isn’t the best for photos need to re-instate gutters and fascia and sort out the drainage but quite happy how it turned out - It was never going to be a quick job and limboing round a post parked smack in the middle of the garage side door would have been awful 3
Nickfromwales Posted Saturday at 18:43 Posted Saturday at 18:43 Still lets a lot of light through. Tres bien. 1
