It seems that Wilko do a Pick 'n 'Mix range of fastenings. The range includes normal sized washers (from ring washers up to 30mm or so), screws and bolts, coach screws and bolts up to about M8 x 80mm, decent sized cup hooks and ring hooks etc.
The quality seems OK, but probably not for critical or external applications.
You get a big resealable bag for £2.99 or a small one for £1.99 and can fill it with anything
Perhaps a good opportunity for anyone wanting to stock up with a range of items, or needing a lot eg if you want hooks for a garage, or a supply of washers.
This was £2.99, and is 2kg of assorted washers wing-nus/bolts and other items. I make it about 600-700 washers for a start, which will probably last me years.
Ferdinand
Edited by Ferdinand
