LadyBuilder Posted December 18, 2017 Posted December 18, 2017 (edited) Hi, I am trying to figure out what to do with my bay window detail. Advice from Nudura has been: 'I note that there are a couple of ‘detailed’ bay windows and I have suggested using our 45 degree corners for this profile but as each of those forms would need to be cut to fit the design then there would be a lot of waste. It mat be possible to form this detail in a different way and thus save a fair bit of money. ' Can anybody suggest alternatives? I am thinking H+H blocks with thin joint for example, but I am worried about the connection detail and air tightness. Edited December 18, 2017 by LadyBuilder
Russell griffiths Posted December 18, 2017 Posted December 18, 2017 I think on the nudura you tube vids they cut the blocks into slices and glue back together to make the correct shape. If you make a ply wood template you could pre cut and glue using the template and carry over in one piece to place in the wall adding reo could be a challenge. Are you bays semi circular? Or segmented like a 50p we used to make a template / profile when doing curved brickwork. I think a similar thing would work.
Russell griffiths Posted December 18, 2017 Posted December 18, 2017 Just had a look while having a cuppa. Nudura do a custom cut radius block. Have a look at there intro vid showing all the different blocks they do.
LadyBuilder Posted December 18, 2017 Author Posted December 18, 2017 Segmented like 50p. The quote in the original post is Nudura. I assume if they had something to suit they would have suggested it. starting to think it is best to just do ground floor in h+h solid wall with thin mortar and kooltherm
