LeserattePD Posted 23 hours ago Posted 23 hours ago Hi all, Can anyone recommend a ground condition surveyor covering Middlesex? Need the survey to support the design of the foundations for our extension and adjoining retaining wall.
nod Posted 18 hours ago Posted 18 hours ago 5 hours ago, LeserattePD said: Hi all, Can anyone recommend a ground condition surveyor covering Middlesex? Need the survey to support the design of the foundations for our extension and adjoining retaining wall. Any local structural Engineer will do it for you
DevilDamo Posted 17 hours ago Posted 17 hours ago 43 minutes ago, nod said: Any local structural Engineer will do it for you It sounds like the OP is referring to a ground/geotechnical investigation of which a structural engineer cannot do.
LeserattePD Posted 16 hours ago Author Posted 16 hours ago Yes, ground condition NOT structural engineer - need to determine appropriate foundations.
Lincolnshire Ian Posted 3 hours ago Posted 3 hours ago Our soil investigation company is based in Leicester, so probably not much help. But as a cost comparison ours was for five 6m sample holes and three 10m resistance holes. The cost was around £2.5k. The testing found peat which meant that we needed two sampling holes which were gas tested every week for 6 weeks. This was another £2k.
