Wookie_73 Posted May 1 Posted May 1 Hi all. Running my ductwork and installing plenums currently. I have a plenum that due to lights getting in the way is currently tucked in a corner. It will eventually have a Ergovent diffuser attached, as shown in the link. https://www.ventilationland.co.uk/en_GB/p/ergovent-frameless-ventilation-valve-round-125-mm/18706/ I currently feel it is too close to the corner of the room at 200mm from the centre to each wall. But I am a bit stuck for space due to lights/ joists etc. Any views? Cheers Dave
Mike Posted May 2 Posted May 2 That type of vent will tend to blow the air vertically downward, so being close to the wall probably won't be a major problem (unless the installation instructions say otherwise). Though unless you have a tiny room I'd imagine that there are some other options. 1
Nickfromwales Posted May 2 Posted May 2 On 01/05/2025 at 15:12, Wookie_73 said: Any views? Yup. Leave it there, install the nice plaster-in one as shown, and go put the kettle on. 😉. You ‘may’ notice a bit of a dust line over 6-12-18 months of operation, but if you use a Ken Dodd stick to keep those walls clean as preventative maintenance I seriously doubt this is any issue whatsoever. ’twill be fine 1
