April 16, 20251 yr Hi all, Had building inspector out today and he wants this tee swapping for a long radius version. Essentially it's at the top of a small backdrop. The rest bend at bottom is just below the water. Does anyone see anything wrong with this? He says 'things' will get stuck at the sharp radius of this tee 😮
April 16, 20251 yr Probably fine, but if they are asking for it to be changed, then a 45° downward bend then a 45° Y junction instead. If it's a backdrop, where's the inspection chamber? Edited April 16, 20251 yr by Conor
April 16, 20251 yr Author There's a manhole under the osb in first pic. New pipe cuts into clay pipe running through manhole. No probs with that. Been doing this 20 years, never seen a long radius swept tee. Apparently my drains are a bit long as well! Think he was on a mission
April 16, 20251 yr I can't ever recall seeing a long radius T. Couldn't Google one. Go with @Conor suggestion.
April 16, 20251 yr Author Thanks for the replies. Got a spare rest bend so will put that on it with a 45deg Y piece in front of it for access.
